Maybe I should have been a bit more clear, after cranking the motor over for the first time I have replaced the oil pump and intermediary shaft, has oil and new oil pressure sending unit. I will pull the valve covers and check the lifters, but for the few seconds that it ran, It did not seem to be missing. I will try all the easiest first and let everyone what I find out. When I did pull the first pump it did have oil in it and the filter.
