in this engine compartment with this radiant heat ice would not last very long.
no fuel pump push rod,,,electric pump..
i do remember somewhere i read that u used the outboards as primary's.
i did read that a return style system would eliminate alot of vapor lock problems,same principal as the vapor seperator,i think i will run it as is thru this summer and over winter convert it to a return style setup.works fine until standing heat hits it after shutoff or stop and go xtreme cruising,.will have to get everything replaced from the gas tank forward
$$.fuel pump,regulator,dual lines.lets see,,,how can i tell the wife i need some overtime from her?
this weekend i will install the msd adj timing control so i can retard it going down the freeway and add the phenolic insulators under the 6-pak to try and eliminate perculation...to be continued..
