Author Topic: Injection Help?  (Read 669 times)
Offline nqkjw
Injection Help?
« on: June 09, 2013 - 06:42:17 AM »
360magnum.
Can anyone tell me if there's a backyard trick to disconnecting the main fuel feed line from the fuel rail?
The book says use special tool pn!@#^ but there's usually a redneck way :grin:
Pic showing joint in question
« Last Edit: June 09, 2013 - 07:26:08 AM by nqkjw »
Burnouts are cool but Traction is the Action
Re: Injection Help?
« Reply #1 on: June 09, 2013 - 10:00:50 AM »
Use tool ^%#$^*%(&^ there is a spring under the steel cup , I have fought with these for hours trying to seperate them even with the tool , you need something that slides over the line & under the cup to lift the spring all the way around so thelip on th eline will slide through the spring , most parts stores have cheap plasctic tools for this .
Offline nqkjw
Re: Injection Help?
« Reply #2 on: June 09, 2013 - 07:48:08 PM »
Ah...OK. I'll have to wait till tomorrow to get something since it's Queen's Birthday public holiday here today.
Offline nqkjw
Re: Injection Help?
« Reply #3 on: June 09, 2013 - 09:42:01 PM »
Got one.
10 second job to disconnect :biggrin:
Helps when you know what you need :cheers:
Re: Injection Help?
« Reply #4 on: June 10, 2013 - 07:23:18 AM »
 :2thumbs:
