Author Topic: Metal dash paint  (Read 1591 times)
Offline shoooter
Metal dash paint
« on: June 09, 2013 - 04:20:38 PM »
How do you paint your metal dash , glove box ect? Do you match it to the dash color an get it painted or does someone sell matched in a can? It will be red? Help?
Offline Cuda Cody
  • Vancouver, WA
Re: Metal dash paint
« Reply #1 on: June 09, 2013 - 07:55:58 PM »
There is a Suede mix you add to the paint to give it the correct look.   I'm not saying this is the best or only place to get it, but this is what you're looking for.
http://www.instrument-specialties.com/products/
Offline shoooter
« Reply #2 on: June 09, 2013 - 08:16:54 PM »
That is black? So I mix it in with the red dash paint? Would that be a single stage paint. Does anyone know the red color paint code?
« Reply #3 on: June 09, 2013 - 08:31:55 PM »
Here's a lower cost option....several reds listed  http://www.herbsparts.com/proddetail.asp?prod=PAINT
Offline 72cudamaan
« Reply #4 on: June 09, 2013 - 08:55:07 PM »
Did you even read the link? It clearly shows "available in colors". Click on the contact icon and I'm sure
they will be able to set you up with the right color.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline shoooter
« Reply #5 on: June 10, 2013 - 01:30:50 AM »
:wow: I did read the link, but it was after I got off of nightshift. Lol sorry I didn't catch the big letters that said available in colors! Ill see if I can get this in Canada. Thanks for the second look 72cudamaan!  I will contact them to see if they have the correct color I'm looking for
Offline drewcrane
« Reply #6 on: June 10, 2013 - 10:11:56 AM »
I too was wondering what kind of paint they used, I tried 5 different kinds and none look right, so I will be getting some of this also :2thumbs: :2thumbs:thanks for the info :woohoo:
Offline tipster
« Reply #7 on: June 11, 2013 - 11:29:43 AM »
its even in the service manual listing that the dash, steering column and some other parts are painted with the suede finish
herbs stuff sounds like a good option, has anyone used it yet and can give some feedback?
Offline shoooter
« Reply #8 on: June 15, 2013 - 02:06:46 PM »
Can this be used on a center consol ? Or is that different stuff
Offline Cuda Cody
  • Vancouver, WA
« Reply #9 on: June 15, 2013 - 05:40:27 PM »
Center Console is molded plastic and this not the correct paint for it.  Use your standard interior plastic paint for a console.  The Suede finish is for the metal dash, metal glove bo,x ash tray, and steering column.
« Last Edit: June 15, 2013 - 05:42:36 PM by C O D Y »
Offline shoooter
« Reply #10 on: June 15, 2013 - 06:22:00 PM »
 :thumbsup: thanks Cody. What paint do I use for the metal trim around the head liner?
Offline Cuda Cody
  • Vancouver, WA
« Reply #11 on: June 15, 2013 - 07:02:39 PM »
That trim has the texture molded in it.  You can use any paint you want that will stick to metal.  Personally, I like to prime them with Epoxy (after them are blasted) then paint with single stage 2 part PPG paint with flattener added in.  I've seen people use "trim black" in a rattle can with good success too.  There are many ways to make it look right because the trim has the texture molded in you only need to get the sheen right to make it look good.
