Author Topic: Yes! New Charger wheels fit old Cudas!!  (Read 5263 times)
Re: Yes! New Charger wheels fit old Cudas!!
« Reply #15 on: June 26, 2013 - 10:58:57 AM »
Everything I've found on late model Charger/Challenger/Magnum says they are 5 on 115. So they are close and with a steel wheel and tapered seat lugnut, you can probalby make them work almost good enough. If you tried to use aftermarket aluminum wheels with a shank lug nut, you would probably find things are not close enough to work. Personally, those look like Intrepid spare steel wheels, which would be a direct bolt on fit.
Late model trucks are 5 on 139.7 so no way will they fit.
Mopar models that do use 5 on 114.3bolt patterns are obviously most classic Mopars from 55-77, 95-01 Avengers, 79-82 Colt, 93+ Intrepid, 91-96 Stealth ( which also means a number of Mitsi wheels share the same bolt pattern), 02+ Stratus, 87+ Grand Caravan, 87-90 Dakota, 49-85 1/2 ton trucks.  Now that isn't to say the backspace will all those wheels will allow them to fit and the hub centric dimensions may be different, but there certainly are a number of wheels that share the same bolt pattern and could bolt on to the classic hub.
