My sending unit had 2 problems, the float was full of gas, had cracks in it, I drilled a hole to drain it and washed it out with water so I could solder the cracks, also the thin resistant wire inside had no contact with the connecting rivet, I put a bit of solder on it so it made contact again, used fosforic acid to be able to solder on that. It works but the float will probably crack again, and I broke one of the tabs by open and closing the thing 3 times, had to solder it shut, so I'm gonna order a new unit, just did this as a quick fix. Wonder if the ones with a plastic float is better than the brass floats?
