Author Topic: aluminum roller rockers...any good?  (Read 2463 times)
Offline CUDA8U
« on: June 17, 2013 - 11:54:42 PM »
 :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada:
Offline cudabob496
Re: aluminum roller rockers...any good?
« Reply #1 on: June 18, 2013 - 12:09:00 AM »
The Crane aluminum roller rockers have been good for me for the last 12 years.
2011 Kawasaki Z1000
« Reply #2 on: June 18, 2013 - 12:25:10 AM »
Really depends who makes them T&D are premium quality , not many others I would use in a street build .
Offline high perf mopar
« Reply #3 on: June 19, 2013 - 09:16:58 PM »
IF u r using them in a street motor and need durability i would suggest stainless..if a roller street application then u def want a high quality rocker,,,i use RAS stainless rockers,,a little pricey but u get what u pay 4....................
« Last Edit: June 19, 2013 - 09:54:49 PM by high perf mopar »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline cudabob496
« Reply #4 on: June 19, 2013 - 10:18:36 PM »
Harland Sharp seems to be on every race track, and they are aluminum?
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #5 on: June 19, 2013 - 10:39:39 PM »
 :clueless:  I believe he mentioned for street use. I would only consider aluminum if they are bushed. The
aluminum wears and then you pay big bucks to save them (if they can be saved).  With a bushing, you press out
the old bush and install new. Resize to shaft.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #6 on: June 20, 2013 - 12:07:06 AM »
also you dont want rollorized shaft rockers,,,,,,no oil pressure..
1971 barracuda
440-6 shaker
b-5 blue
Offline cudabob496
« Reply #7 on: June 20, 2013 - 12:23:37 AM »
ok, but I've got aluminum Crane Gold rollers that are seeing solid roller cam  .625 lift and 470psi open pressure springs, and for
12 years they seem to be performing flawlessly. I rarely have to adjust valve lash any more.
2011 Kawasaki Z1000
« Reply #8 on: June 20, 2013 - 01:04:52 AM »
after there set thats what i experianced too,,,the myth about constantly adj solid lifters is just that..a myth,,same for my last 2 cars..WITH good quality componets..and of course no componet failuires...
1971 barracuda
440-6 shaker
b-5 blue
Offline cudabob496
« Reply #9 on: June 20, 2013 - 02:35:52 AM »
Also, and obviously I'm biased, lash adjustment is necessary due to metal wear. Since synthetic oil flows quicker at startup, and lubricates better, I think
thats another reason why my lash has rarely needed adjustment. For last 7 years, I might have to make a minor adjustment to one or two at the most.
And I may have just been being too picky when I adjusted them in the first place.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: June 20, 2013 - 08:51:41 PM »
Yes they are aluminum and bad a$$....
Harland Sharp needle bearing, single shaft mount, rockers for Big Block Chrysler are like no other on the market. The only shaft rocker of this style to feature heavy duty needle bearing fulcrums matched with specially heat treated, heavy wall, rocker shafts. Harland Sharp Mopar kits are designed for extreme applications with valve springs up to 1.650 diameter and .900 lift cams. The 7/16-20 x 5/16 ball adjusters are designed for use with the factory style pushrods, length to be determined after you have rockers installed. Kits include rocker arms, shafts, spacers, hold down clamps, adjusters and nuts. See our instruction link for replacement and service parts #s.
Offline cudabob496
« Reply #11 on: June 21, 2013 - 12:03:34 AM »
Well, street use can mean a lot of things. It can mean "grocery getter", or, defend the
Mopar honor against the new Camaros and Mustangs at all costs!.
2011 Kawasaki Z1000
