Author Topic: More vibration, noise issues  (Read 598 times)
Offline mikeljAAR
« on: June 18, 2013 - 09:28:12 AM »
My recently restored, total stock configuration AAR has an annoying whine when under load at lower speeds, and a vibration above 65 mph through the console area.  All driveline parts are new, and it does it no matter which sets of wheels and tires I use. Any suggestions?
"I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment"
Re: More vibration, noise issues
« Reply #1 on: June 18, 2013 - 09:36:37 AM »
probably driveline angle again , must be a problem in the trans creating the whine
Offline mikeljAAR
« Reply #2 on: June 18, 2013 - 11:21:24 AM »
Thanks, that angle must be a commonly messed up item when these cars are redone, you wonder why so many get it wrong.  I have an auto, which is what makes the whine more interesting, I will try different gears and see if it is affected, thanks!
Offline cudabob496
« Reply #3 on: June 19, 2013 - 01:09:18 AM »
buying a high quality well balance drive shaft can help a lot.
These guys sold me a nice one:
http://www.dennysdriveshaft.com/
a local guy balanced my old one, but the new one from Denny's is a lot smoother at high speed/rpms.
Plus, its a lot stronger.
« Last Edit: June 19, 2013 - 01:11:17 AM by cudabob496 »
2011 Kawasaki Z1000
