Author Topic: 383 timing ?  (Read 1943 times)
Offline Racer57
383 timing ?
« on: June 18, 2013 - 10:52:47 PM »
70 Cuda,  HP 383, 600 Eldebrock, 4-speed
What should it be timed at and with electronic ignition should the vacuum advance be hooked up ?
Thanks.
Re: 383 timing ?
« Reply #1 on: June 19, 2013 - 09:29:40 AM »
generally they run best with 12-16* initial timing & 34-36 * total timing above the curve & no vacuum advance
Offline Racer57
Re: 383 timing ?
« Reply #2 on: June 19, 2013 - 09:34:00 AM »
Thanks !  Those are the numbers I suspected, but wanted to make sure.
