Author Topic: A833 18 spline diffs?  (Read 746 times)
Offline Cuda416
« on: June 18, 2013 - 11:57:30 PM »
Everything I've read and seen has told me that the only real difference between an 18spline and 23 spline 833 is the input shaft and front bearing retainer etc. I was told by someone yesterday that the tail shaft housing is also different in that it has a larger bearing as well. Is this true? The pictures I've been able to dig up don't really tell me anything either way.
-C
70' Barracuda conv. (project)
Re: A833 18 spline diffs?
« Reply #1 on: June 19, 2013 - 10:16:44 AM »
The rear brg may have been smaller in some of the A biody trans but all the ones I have had apart use the 308 rear & the 307 or 308 front brg , the gear set was unique as well even 23 spline trans had various gearsets that have to change as a set .
Offline 70CUDA4SPEED
« Reply #2 on: June 19, 2013 - 11:51:49 AM »
House it's not the same, a 23 splines house is weaker, they are not as thick as the 18 splines house.
« Reply #3 on: June 19, 2013 - 06:23:20 PM »
True , the input shaft is larger diameter & the gear pitch is different , definatly a stronger unit
