Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Mopar Cam specs
« previous
next »
Print
Pages: [
1
Author
Topic: Mopar Cam specs (Read 590 times)
john h
Jr. Member
Mopar Cam specs
on:
June 19, 2013 - 12:23:45 PM »
how do we know if the max lift on the Mopar cam is listed as @.050" timing or seat to seat timing? it seems to make a really big difference in Torque and Hp curves on computer dyno programs.
John
Logged
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
Strawdawg
Resident
Re: Mopar Cam specs
Reply #1 on:
June 19, 2013 - 01:25:34 PM »
Normally both the advertised duration and the lift at .050" is shown on the cam card and in the cam description
Logged
Steve
www.vortexbuicks-etc.com
Chryco Psycho
Administrator
C-C.com Guru
Re: Mopar Cam specs
Reply #2 on:
June 19, 2013 - 02:02:00 PM »
lift is lift from seat to full open max lift doesn't vary
Duration varies a lot , advertised duration is 8* , .050 is more accurate & will make a big difference in fast ramp cams as you can get more duration between seat & .050 lift
Logged
john h
Jr. Member
Re: Mopar Cam specs
Reply #3 on:
June 19, 2013 - 02:28:34 PM »
I'm putting my exact combo in the computer to see how close the numbers match to the dyno numbers for Mopar performance on a 360 crate motor. I want to see what difference good or bad a single plane intake makes over a dual plane, and I can't match the numbers unless I know what value to use. Seat to seat timing or @.050" timing. the cam I have is listed as 274/264 .433"/.430" using this cam and the 2 different ways of timing yields an increase of 30+ hp and 70+ ft/# torque for a seat to seat measurement. neither are that close as to what Mopar claims on their Dyno but the seat to seat is closest.
Of course I need to figure out my spark issue before messing with anything else. Just playing around with combos right now.
John
Logged
John
73 Cuda
360 Crate motor
Chryco Psycho
Administrator
C-C.com Guru
Re: Mopar Cam specs
Reply #4 on:
June 19, 2013 - 06:14:36 PM »
using a Lunati cam you should be around .480 lift with similar duration @ 50
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Mopar Cam specs
