Author Topic: What size carb should be on my 440?  (Read 14474 times)
Offline Strawdawg
    • Vortex Buicks
Re: What size carb should be on my 440?
« Reply #60 on: July 14, 2013 - 09:01:25 PM »
which timing set did you buy?  Normally, most seem to allow 2 degs, or even increments
Offline jhaag
« Reply #61 on: July 14, 2013 - 09:56:49 PM »
your crank sprocket has 3 keyways, 1 will be for zero advance, 1 will advance the cam, and 1 will retard cam timing. look at your instructions or online for which 1 does what. also you can get bushings for the cam sprocket that will allow you even finer tuning. If I were you I would go with what you have. 1 degree will not make a significant difference on a street motor. by the looks of the slop in your old chain, just replacing it will make more difference.
love 70 Challengers
Offline all4rocks
« Reply #62 on: July 15, 2013 - 12:26:25 AM »
that's what I was thinking. 1 degree shouldn't make a difference. I also did a centerline degree on the same intake valve and came up with 107 1/2 degrees and the card says 108 so should be close enough....I think.
« Reply #63 on: July 15, 2013 - 07:17:05 AM »
 :2thumbs:
Offline Strawdawg
    • Vortex Buicks
« Reply #64 on: July 15, 2013 - 09:40:37 AM »
bout as close to perfect as you are going to get.  I think Chryco is right.  the centerline method is the most accurate.
Offline all4rocks
« Reply #65 on: July 16, 2013 - 08:18:44 PM »
I got it altogether and just need to put on the oil pump. Chryco said prime it with grease. Which hole.....the impellar one or the one where the filter spins on? What kind of grease?
« Reply #66 on: July 17, 2013 - 12:23:44 AM »
bearing lube is best , just coat the rotors so they will seal & pull oil up
Offline all4rocks
« Reply #67 on: July 28, 2013 - 11:58:53 AM »
got everything back together and ready for startup. The new oil filter is on and since it sits at 90 degrees to the engine you cant fill it up to the top and thread it on. I did fill it as much as I can and threaded it on. I am a little hesitant on starting it like that since it wont have immediate oil pressure. Should I take a drill and wind the oil pump first to get the oil flowing? I heard you can buy one of those long shafts for doing that through the distributor hole.
« Reply #68 on: July 28, 2013 - 04:39:01 PM »
fire it up it will only take a second to fill the filter & pressurize it .
Offline all4rocks
« Reply #69 on: July 29, 2013 - 01:41:26 AM »
I cant figure out where to mount the coil. The new fuel rail is in the way of the original mounting spot. Any ideas?
« Reply #70 on: July 29, 2013 - 09:16:24 AM »
I usually use the one mounting hole still accessable & turn the coil sideways in front of the carb
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #71 on: July 29, 2013 - 06:46:55 PM »
I put on a Holley Street Avenger 770CFM with electric choke and vacuum secondaries.     Runs great so far...... out of the box.
My research suggested this for my stock 440 HP motor.
All the best ..... CHAPS
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline all4rocks
« Reply #72 on: July 31, 2013 - 12:56:24 AM »
Do I need to run premium fuel in this motor? What would be best for it?
« Reply #73 on: July 31, 2013 - 04:20:40 PM »
Definitely. The octane ratings of today don't compare to yesteryear.
Offline all4rocks
« Reply #74 on: July 31, 2013 - 06:09:41 PM »
What about the fuel being unleaded? Are the heads made for leaded fuel?
