Author Topic: Holley/AFR question  (Read 729 times)
Offline cudabob496
Holley/AFR question
« on: June 22, 2013 - 11:13:20 PM »
So, on my 12 year old 850 DP, no matter how low I go on the primary jets, I can't seem to get the AFR
above 11.5.  At WOT its about 12.5, so that is good. Did someone recently say I should consider drilling
small holes in the primary butterflys. Seems that might solve the problem?
2011 Kawasaki Z1000
Re: Holley/AFR question
« Reply #1 on: June 22, 2013 - 11:28:56 PM »
if the idle is turned up a fair bit exposing the ilde transfer slots too much it could run rich or just lose idle sensitivity , drilling holes in the throttle plates help allow more air in while keeping the transfer slots covered
Offline cudabob496
« Reply #2 on: June 22, 2013 - 11:56:50 PM »
hmmm, got idle at 1400.  How many holes, what size, and wear drill on the plates? thanks
2011 Kawasaki Z1000
« Reply #3 on: June 23, 2013 - 06:07:30 AM »
Start small 3/32 opposite from the idle slots in the center of the throttle plate
