Author Topic: Break In Oil  (Read 1235 times)
Offline AMXguy
Break In Oil
« on: June 23, 2013 - 12:16:12 AM »
I'm going to use Brad Penn break in oil on this engine, normally I use the old EOS and standard oil then change the oil after an hour of running.
Should I do the same thing with this oil or spin a new filter on and run it a little longer?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Break In Oil
« Reply #1 on: June 23, 2013 - 06:08:41 AM »
you should be able to run it for 400 miles or so
Offline AMXguy
Re: Break In Oil
« Reply #2 on: June 23, 2013 - 08:36:48 PM »
Ok, I'll just spin on a new filter and run it a while.   thanks
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Break In Oil
« Reply #3 on: June 23, 2013 - 09:33:19 PM »
There are many different thoughts on this.  Some say drain it right after the 20 minute cam break-in.  Others say you can drive it awhile.  The bottle of Lucas Oil break-in additive I used says to change after 1000 miles.
Re: Break In Oil
« Reply #4 on: November 03, 2013 - 06:36:02 PM »
What viscosity do you recommend?
Should I go staright 30W? Or a multi Wt?
I see Brad Penn offers a semi synthetic as well.
I think it's more suitable for Catlytic cars?
Re: Break In Oil
« Reply #5 on: November 03, 2013 - 08:43:22 PM »
Re said:
What grade/viscosity did you do a break in on if you are running a flat tappet cam?
Outside temp break in for me will be between 60-70 degrees.
I'm feeling the 10-30W should be O.K. Is that a good viscosity?
When I went to Summit website, it says the 30 weight as a break in oil.
 :1zhelp:
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
Re: Break In Oil
« Reply #6 on: November 03, 2013 - 09:04:50 PM »
I used the Comp Cams Break in oil and then changed the oil to Royal Purple 10W 30.  No issues.
Re: Break In Oil
« Reply #7 on: November 03, 2013 - 09:38:35 PM »
i once heard that bearing clearances and outside temps are the deciding factors on what weight beak in oil to use.
Then I hear it's what a personal preference you like. Brad Penn is what I hear to use.
Offline 72cudamaan
Re: Break In Oil
« Reply #8 on: November 03, 2013 - 10:07:47 PM »
I have always  broke in all engines with straight 30# oil. If you're not going to drive the car in the really cold temps, then there is no reason to use a multi weight anyway.
If I cant fix it, it's broke
Andy  (phukker whither)
Re: Break In Oil
« Reply #9 on: November 04, 2013 - 10:30:39 AM »
I have used the 10-30 Z Alt , or just used additives in regular oil such as Comp Cams or others in regular high quality oil like Castrol GTX I generally use 10-30 or 10-40 , never 20-50 unless the engine is a race build with higher brg clearance
