Author Topic: Anyone using one of these? Seems like a good idea? Sacrificial Zinc Anode  (Read 1736 times)
Offline cudabob496
2011 Kawasaki Z1000
Offline anlauto
I have one in my swimming pool... :dunno:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
They are starting to be popular with hot rodders now that most have aluminum radiators ,engine blocks ect, They are a good idea , anything you can do to keep corrosion down in your cooling system well worth it IMO
Seems like a good idea, expensive though for what you get? I have one in the hot water tank in my travel trailer and its 1.2" NPT by about 10" long and 3/4" diameter and it's only about 10 bucks.
Offline Strawdawg
    • Vortex Buicks
Good coolant, or an additive to keep the ph right, plus good grounds and there should not be a problem.  This is more a bandaid than a cure
Offline cudabob496
wish I could just drop one in my radiator, but I think it has to be bolted in, so the corrosion current will be completed.
2011 Kawasaki Z1000
Offline 7212Mopar
Engine cooling is a closed system with no raw makeup. I don't think it is necessary. Coolant already has corrosion inhibitor.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline cudabob496
Not sure that the coolant corrosion inhibitor is always adequate for all corrosion mechanisms the engine might experience,
especially with all the newer materials.
And of course, the level of corrosion inhibitor might vary, depending on strength of anit-freeze you have in your car.
This zinc may be a good insurance policy.
I just went down to an 80wtr/20 mix to help my engine run cooler.
« Last Edit: June 26, 2013 - 06:09:18 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
If you ever pass thru west Texas, I can show you an aluminum radiator that is about 15 years old that has straight water plus and additive run at least six months a year for more than ten years of the 15 and it has no corrosion.  I continue to think this is a "problem" that was created to justify a magic part instead of promoting good maintenance.  :)
At this point in time, I suspect I potentially have more problem with the fin bonding on the tubes than I do any interior problems.  People often don't realize that the quality of the bond between the fin and tube deteriorate with time and the cooling efficiency of the radiator suffers as a result.
Offline cudabob496
But the corrosion can be occurring at other locations other than the radiator. Aluminum components like heads can perhaps result
in block corrosion, due to dissimilar metals.  Also, the quality of engine grounds might affect corrosion rates. If you install this zinc anode,
and in a few years it is corroded, then that shows its working. We use to strap large zinc blocks on the hull of our submarine, which was continually
generating a lot of electricity, similar to a car alternator.
« Last Edit: June 26, 2013 - 07:21:28 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
good grounds and maintaining the correct ph in  the coolant whether water or antifreeze will prevent electrolysis.  Many, Many modern cars have aluminum heads, blocks, and/or radiators and don't have a problem.  It goes into the same category as Fitch fuel Catalyzers, air craft sparkplugs, etc.  Science triumphs over voodoo anyday :D
Offline cudabob496
I suppose one of these would bolt into my water pump housing. I'm not using my heater hoses.
I know that when I tried to drain my block once, there was a lot of rust particles blocking the drainage, until I jammed
a screw driver up there.
http://www.zincwarehouse.com/engine-zincs.html
« Last Edit: June 27, 2013 - 03:52:33 AM by cudabob496 »
2011 Kawasaki Z1000
Offline 06Daytona
You  can go to a marina or boat sales place and pick up a zinc bar and just screw it onto the car somewhere. Zinc won't work to stop corrosion on aluminum because aluminum will sacrifice before zinc. Big fishing boats with steel hulls use them to keep the rust down on the hull and they get replaced every year.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
