Author Topic: Wow - Coolant temp drops 10 degrees  (Read 1815 times)
Offline cudabob496
« on: June 25, 2013 - 07:52:31 PM »
Wow, going to 80% water, 20% antifreeze lowered my coolant temp by 10 degrees!
Good solution for hot summer driving.
Even with 20 %, you still get freezing protection down to 20 degrees I think.
« Last Edit: June 25, 2013 - 09:38:04 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Wow - Coolant temp drops 10 degrees
« Reply #1 on: June 25, 2013 - 08:02:55 PM »
Good to know!  :thumbsup:
What was you mix before?  :clueless:
Offline cudabob496
« Reply #2 on: June 25, 2013 - 08:05:23 PM »
50/50
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: June 25, 2013 - 08:31:23 PM »
Science works
« Reply #4 on: June 26, 2013 - 12:15:34 AM »
not so good in Canada where it can drop below freezing even in the summertime
Offline cudabob496
« Reply #5 on: June 26, 2013 - 03:25:06 AM »
good point, but all ya gotta do is siphon out a gallon from the rad, and poor a gallon of Prestone in,
and you're ready to go below 20 degrees.  I just ordered one of those cheapy little coolant testors
to make sure I am accurate on my percentage of Prestone in the coolant system.
2011 Kawasaki Z1000
« Reply #6 on: June 26, 2013 - 09:13:51 AM »
I used 70 % mix as we regularly get below -40C , I would hate to forget & have to replace the engine
Offline cudabob496
« Reply #7 on: June 27, 2013 - 07:22:40 PM »
found out I'm 30% coolant strength, so going to 20% may get a larger temp drop.
Can hurt, especially if you're driving in 90+ degree weather!
(or 100+ if you live in Texas!!)
2011 Kawasaki Z1000
Offline gafletch
« Reply #8 on: July 05, 2013 - 08:54:53 AM »
Has anyone tried any of the coolant additives? Just wonder if it helps, or if it's a gimmick.
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: July 05, 2013 - 09:53:24 AM »
The simplest are ones like Water Wetter are basically surfactants so they help a little.  I found it to need to be replenished every few months when using with straight water or it would start getting rusty.  The alternative is to add some water pump lube (Prestone makes one).
Royal Purple Ice has a good rep from what I recall.  It is supposed to be reformulated, I think.  Good for cars with aluminum radiators, etc.
As I mentioned above, I use RMI-25 which I order by the quart and use 8 ozs at a time per car (suggested to use 16 oz with straight water for a yearly use).   It works well to soften and remove deposits from the block as well as well as act as a surfactant and lube.  It does a good job on radiators to prevent old antifreeze from precipitating out in the radiator tubes or block.  The block and radiator will stay very clean if you use it.  Developed for long haul truckers.
I usually order it online for the best price and it is hard to find unless you go to a heavy truck shop.
But, yeah, it all works.  I would say five to ten degrees is common although some claim more.  Works best in a clean block and that is why I like the RMI-25.  It gradually cleans deposits out.  You will see the scum floating on the surface when you remove the cap.
« Last Edit: July 05, 2013 - 10:09:28 AM by Strawdawg »
Offline cudabob496
« Reply #10 on: July 05, 2013 - 09:41:32 PM »
I'm sold, I'll buy some!!
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: July 05, 2013 - 10:10:25 PM »
I used my last 8 ozs this morning and ordered another quart :)
Offline cudabob496
« Reply #12 on: July 05, 2013 - 10:30:15 PM »
Well, I must confess, I just went with the Royal Purple on Summit, since they did not have RMI-25.
I'm impatient!  Only $15. Should have used this long ago!
http://www.summitracing.com/parts/rpo-01600
« Last Edit: July 06, 2013 - 06:01:33 AM by cudabob496 »
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #13 on: July 06, 2013 - 12:11:53 AM »
I think RP reformulated it a couple of years ago to be more like the RMI.  Should work fine.
I ordered from amazon for $22 for a quart which is enuf for four treatments....
