Author Topic: fuel pressure regulator setting  (Read 550 times)
Offline high perf mopar
« on: June 25, 2013 - 08:53:47 PM »
i have an aeromotive #13205 pressure regulator,with there pressure gauge, thats plumbed into a dead head system,3/8" lines,mallory comp 110 at the tank.1 filter before the pump,1 after the regulator.
set pressure motor off,5 1/2 lbs,been this way  for awhile,maintains that setting for awhile but,today while retuning the motor after some upgrades/changes,the pressure dropped to 3.8?and stayed there?no flucuation that i could see.
after cooling down back to 5 1/2 lbs???instructions that came with it says to set while motor's running,,wont it blow past the shutoff seat upon cold start if i do this...    :dunno:
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline cudabob496
Re: fuel pressure regulator setting
« Reply #1 on: June 25, 2013 - 09:26:56 PM »
your basic Holley needs 6 psi to 7.5 to work, and I suspect getting seat leakage would require
8 or 9 psi at least, but just a guess.
Those little tiny gauges in the engine compartment on the fuel systems can be really inaccurate.
I trust the 2 and 5/8 electric autometer on my dash much more!
2011 Kawasaki Z1000
« Reply #2 on: June 26, 2013 - 12:18:32 AM »
I stay below 6 with carbs , at WOT the float may not have enoiugh fuel in the bowl to hold the valve closed & could flood above 6psi , at low rpm generally this is not a problem , even with lower pressure as long as the volume is consistant you will not have an issue
