Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Sending unit leaking at tank....Does it have a gasket in there?
« previous
next »
Print
Pages: [
1
Author
Topic: Sending unit leaking at tank....Does it have a gasket in there? (Read 1655 times)
all4rocks
Jr. Member
on:
June 25, 2013 - 10:54:07 PM »
Gas is leaking badly at sending unit to gas tank. Is there a gasket that can be replaced? Where do I get it?
Logged
brads70
C-C.com Expert
Re: Sending unit leaking at tank....Does it have a gasket in there?
Reply #1 on:
June 25, 2013 - 10:57:21 PM »
Yup... Try Dave at Roseville!
Logged
burdar
Sr. Resident
Reply #2 on:
June 25, 2013 - 11:05:32 PM »
Is the tank original? A lot of people have had problems with the new lock rings. They are a little thinner. The new gaskets are a little thinner too. That adds up to a leak.
Logged
all4rocks
Jr. Member
Reply #3 on:
June 25, 2013 - 11:15:26 PM »
original tank with new sending unit and lock ring. If its too thin, how do I fix that?
Logged
tman
Sr. Member
Reply #4 on:
June 25, 2013 - 11:26:42 PM »
Try your original lock ring. I did not have a problem using a new lock ring, new sender, with the gasket it came with. I did notice though that the rubber gasket did not center too well and I had to manipulate it during install to keep it centered.
Logged
burdar
Sr. Resident
Reply #5 on:
June 25, 2013 - 11:28:41 PM »
I didn't have a problem with mine either but a lot of people have. Try the original lock ring.
Logged
all4rocks
Jr. Member
Reply #6 on:
June 25, 2013 - 11:30:11 PM »
I just bought the car and it had the new sending unit already installed, so I don't have the factory ring. any suggestions?
Logged
hooD
detroit iron
Resident
Motor City Made Muscle
Reply #7 on:
June 26, 2013 - 04:47:20 AM »
make sure as others have said that your rubber washer is in good shape and that your lock ring is clean and that it is "locked into place".
rubber washer
clean up the lock ring
make sure the lock ring is snugged tight so it seals (picture of before i took the sending unit out and cleaned stuff up)
Last Edit: June 26, 2013 - 04:50:21 AM by hooD
Logged
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
http://www.youtube.com/watch?v=1e4-yOrEEI4&feature=g-upl
*click my E-Body*
dodj
Sr. Resident
Reply #8 on:
June 26, 2013 - 09:56:22 PM »
To take up the slack with a new lock ring you might try two gaskets?
Logged
1973 Challenger 440 4 spd
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
