Author Topic: diff 8-3/4  (Read 703 times)
Offline cudamadd
    • cudamad157071@gmail.com
diff 8-3/4
« on: June 26, 2013 - 02:21:12 AM »
This sounds like a stupit question . 1970  ebody 8 - 3/4   were is the drain plug   ?  489 case cheers. :clueless:
Go 4 a spin Ya Why Not.
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
Re: diff 8-3/4
« Reply #1 on: June 26, 2013 - 02:28:55 AM »
There isn't one you have to loosen the bolts and pry forward a bit and creat a gap between the third member and the housing. Probably the worse design ever lol best to add one in yourself for ease later on down the road.
Cuda James
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline cudabob496
Re: diff 8-3/4
« Reply #2 on: June 26, 2013 - 02:50:51 AM »
A drain plug could weaken the housing, but would have been nice.
you can siphon it out.
I used one of these to get it going, then it just drained over night into a small plastic tub.
You should get about 2 quarts out.
http://www.summitracing.com/parts/anm-cp7835
But there's all kinds of ways to suck it out. A lube joint can do it for you. It smells so bad, that may be the way to go.
I use this:
http://www.summitracing.com/parts/red-57904
« Last Edit: June 26, 2013 - 03:27:35 AM by cudabob496 »
2011 Kawasaki Z1000
Re: diff 8-3/4
« Reply #3 on: June 26, 2013 - 08:26:51 AM »
I made my own fill and drain plugs when I ran a 8 3/4"  worked great and not hard to do.
