Author Topic: NO NAME  (Read 22359 times)
Offline Kilgore20
Re: NO NAME
« Reply #30 on: January 11, 2014 - 06:52:24 PM »
More pics
Offline hemiken
Re: NO NAME
« Reply #31 on: January 11, 2014 - 07:37:18 PM »
Wow, that sucks. It will be easier and cheaper in the long run to swap out that firwall cowl section with a new AMD piece, it will be a lot better way to go about repairing this section, you will thank yourself in the long run for changing the whole thing out. :2thumbs:
Re: NO NAME
« Reply #32 on: January 11, 2014 - 07:57:11 PM »
 :iagree:
Remember to graft in your cowl vin stamping onto the AMD new part.
Nothing illegal being done so long as all Vins match that were originally with the car.
Offline Kilgore20
Re: NO NAME
« Reply #33 on: January 12, 2014 - 12:11:04 AM »
Its defiantly to far gone to save. I have been looking at the replacement stamped sheets. whats yalls experience on the different company's and the quality of their stamped product. I am really dreading replacing it. Any words of advice.
Offline hemiken
Re: NO NAME
« Reply #34 on: January 12, 2014 - 01:19:40 AM »
Simply go with the AMD firewall section, you will not regret replacing, it is much easier than patch fixing, just brace your door openings now before you remove anything at all, brace from floor to roof gutter and from B-pillar to door hinge, plus a cross brace from side to side will secure the lot to stop anything moving while you remove the entire damaged area. :2thumbs:
Offline cudamadd
    • cudamad157071@gmail.com
Re: NO NAME
« Reply #35 on: January 12, 2014 - 03:45:51 AM »
 You are going to save a lot of time and your knuckles . If you replace it with  an AMD fire wall section . Good luck  it will look great when you are done.
Go 4 a spin Ya Why Not.
Offline jimynick
Re: NO NAME
« Reply #36 on: January 12, 2014 - 09:56:40 PM »
:iagree:  Yep, definitely the way to go. Mine's also rotted and I bought the AMD upper and lower firewall. The advice about bracing the car is very good advice and don't ignore it or you'll make yourself a lot more work. You bought the car so right that you're still not in over your head here; just take your time as you seem capable of it. Put some rust paint on the inner surfaces, less the weld areas and do yourself a favour. Good luck.  :thumbsup:
Re: NO NAME
« Reply #37 on: January 13, 2014 - 09:14:46 PM »
The top portion to install:
I've heard of using the auto body epoxy is a good choice.
Reason being; is that it helps it become a better sealed, leak proof adhesion.
The factory had huge tongs and a dum dum material to spot weld them together.
« Last Edit: January 13, 2014 - 09:16:31 PM by Topcat »
Offline Kilgore20
Re: NO NAME
« Reply #38 on: May 06, 2014 - 10:36:21 PM »
So its been along time since I have messed with my baby. I have officially moved my car out of the shop. I have come to the conclusion that if the fire wall is that bad im gonna let my buddy who owns a body shop do it. Im also gonna let him do the rear quarter panel. The only problem is he is about six months behind due to the recent natural disasters we have been suffering.
So i pushed the car out back and covered it up and moved all the small parts in to begin work. It has been a long time since i have done metal fabricating.
It has been just as long since i have welded thin metal. So with all that said lets get to it.
Offline Kilgore20
Re: NO NAME
« Reply #39 on: May 06, 2014 - 10:45:05 PM »
I have pictures I swear! If any body has a helpful hint on how to resize my photos please let me know.
Offline Kilgore20
Re: NO NAME
« Reply #40 on: May 06, 2014 - 11:01:43 PM »
Pics
Offline Kilgore20
Re: NO NAME
« Reply #41 on: May 06, 2014 - 11:10:33 PM »
More pics
Offline Kilgore20
Re: NO NAME
« Reply #42 on: May 06, 2014 - 11:11:57 PM »
pics
Offline Kilgore20
Re: NO NAME
« Reply #43 on: May 06, 2014 - 11:13:01 PM »
pic
Offline turbo224
Re: NO NAME
« Reply #44 on: May 07, 2014 - 10:40:05 AM »
Looks like some good progress, keep it up!
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
