Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
10.5" or 11" clutch ?
« previous
next »
Print
Pages: [
1
Author
Topic: 10.5" or 11" clutch ? (Read 900 times)
Racer57
Sr. Member
on:
June 27, 2013 - 10:46:09 PM »
70 Cuda HP383 23 spline 4-speed.
How do I determine without tearing everything apart whether I have a 10.5" or 11" clutch ? If I have a 10.5 can a 11 be used or is the flywheel different also ?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 10.5" or 11" clutch ?
Reply #1 on:
June 27, 2013 - 11:18:46 PM »
Alum Bell = 130 tooth flywheel 10.5 or 10.95" pressure plate , same bolt pattern , I always use the larger diameter for longer life & more grip
Iron bell = 143 tooth flywheel , different pressure plate & bolt pattern but same 11" disc as 130 set up
Logged
Racer57
Sr. Member
Reply #2 on:
June 28, 2013 - 08:21:52 AM »
Thanks !
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
June 28, 2013 - 11:02:34 PM »
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
