Author Topic: Best valve spring compressor/tool?  (Read 4433 times)
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
« on: June 28, 2013 - 11:37:05 PM »
Gearing up for an a cam swap...  small block Mopar....  My worry?  Swapping the valve springs w/heads installed.
So there is this Proform 67460 Valve Spring Compressor:
http://www.jegs.com/i/Proform/778/67460/10002/-1
but worried about interference around power brake booster and master cyl.
And this style Comp Cams 5606:
http://www.jegs.com/i/Comp+Cams/249/5606/10002/-1
but worried about it being a piece of junk, clunky, and slooooooowwwwww.
I thought about buying both...?
Opinions?
Offline LEMOOREACE
Re: Best valve spring compressor/tool?
« Reply #1 on: June 28, 2013 - 11:39:55 PM »
Whoops, wrong post section, my bad...  somebody bump me!!!
Offline LAA66
« Reply #2 on: June 29, 2013 - 09:41:38 AM »
 Using the hook and twist compressor may cause damage (small nicks) to the spring but it's quick and easy. I used one for years but have broken several springs down the road, can't say if it's related or not.
 I decided to make a lever type out of an old rocker arm welded it to a rod. Cut a large flat washers in half and weld to the sides of the rocker to press on the retainer. It's a two person job to use it though, one to hold the arm down and the other to remove/replace the clips.
 Either way you will need an air hose adapter to charge the cylinders during the operation.
« Reply #3 on: June 29, 2013 - 11:11:51 AM »
Mancini has the best on engine compressor I have used , it bolts to the rocker shaft stands & has tis own shaft , you just rock it down to compress the springs
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: June 29, 2013 - 11:19:56 AM »
Offline LEMOOREACE
« Reply #5 on: June 29, 2013 - 11:59:43 AM »
The one at Mancini is the same Proform...   Can you confirm this is the one were talking about...
Item# PFM-67460
http://chucker54.stores.yahoo.net/en2pivaspto.html
« Reply #6 on: June 29, 2013 - 12:48:00 PM »
yes , same part
Offline LEMOOREACE
« Reply #7 on: June 29, 2013 - 02:30:49 PM »
No clearance worries to getting this tool on the driver's side back valve springs with the master cyl and booster? Or do you think will they need to be pulled?
« Last Edit: June 29, 2013 - 02:57:37 PM by LEMOOREACE »
« Reply #8 on: June 29, 2013 - 09:41:08 PM »
I have always made it work
Offline jimynick
« Reply #9 on: June 29, 2013 - 11:38:58 PM »
It was mentioned, but don't forget to run the piston up to TDC on each cylinder AND make or buy an air fitting to screw in the plug hole to hook an air line to, while changing the springs. Dropping a valve into the cylinder will NOT make you happy.  :2cents:
Offline jvike
  • Pro-Touring Cuda
« Reply #10 on: July 03, 2013 - 05:36:39 PM »
Use this and weld/fab up an adapter for the spring  :thumbsup:
Offline vinb
« Reply #11 on: July 03, 2013 - 06:50:05 PM »
My friend that owns http://drcraceproducts.com/catalog.html makes them and sell's them to other companies..
Great Tool....
Offline nqkjw
« Reply #12 on: July 04, 2013 - 06:22:39 AM »
Or fill the cylinder with nylon rope through the spark plug hole and wind the piston up.
Burnouts are cool but Traction is the Action
Offline LEMOOREACE
« Reply #13 on: July 04, 2013 - 04:58:45 PM »
Thanks all...  I think I have my plan together thanks to jvike.  I'm going to set the drill press across the lifter valley and press away.... checking to see if it fits under the hood today.
lol
No prices at http://drcraceproducts.com/catalog.html ???  But I'd be willing to go this route if the price is right in relation to the Proform model of the same design.
Offline StRoKeR
« Reply #14 on: July 08, 2013 - 02:47:32 PM »
« Last Edit: July 08, 2013 - 02:52:00 PM by -Sledgehammer- »
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
