Author Topic: Junkyard brake upgrade?  (Read 2021 times)
Offline RCCDrew
« on: June 30, 2013 - 08:57:13 AM »
I found a 73 fury in a junkyard. Smallblock car. Would the disc brakes be interchangeable with my 73 cuda? Would there be any upgrade with the swap?
What cars would be good upgrade brake donors?
Re: Junkyard brake upgrade?
« Reply #1 on: June 30, 2013 - 09:36:17 AM »
the Fury should be a C body & will not swap , the 73-75 A body is a direct swap or look into the Scarebird parts
Offline BIGSHCLUNK
« Reply #2 on: June 30, 2013 - 10:14:16 AM »
The BIG Fury? , the coveted 73 ONLY spindles..... !  Brad will chime in on this I'm sure.  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline RCCDrew
« Reply #3 on: June 30, 2013 - 03:19:07 PM »
Yes this is a 73 fury with the flip up headlights.
Are the A body parts an upgrade?
Offline cudazappa
« Reply #4 on: June 30, 2013 - 08:08:19 PM »
What are you starting with on your cuda?  Drums or discs!
2015 Dart GT - Daily Driver
Offline RCCDrew
« Reply #5 on: June 30, 2013 - 09:49:12 PM »
I believe that all 73s have discs.
Offline BIGSHCLUNK
« Reply #6 on: June 30, 2013 - 10:19:59 PM »
the 73's are the one's you need to do the Viper upgrade!  :burnout:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline RCCDrew
« Reply #7 on: July 01, 2013 - 10:28:11 PM »
Are the 73 c body calipers better than the e body calipers?
Offline Katfish
  • 70 Challenger
« Reply #8 on: July 01, 2013 - 10:32:18 PM »
Link has everything you need to know.  Get the 73-76 A-body spindles
http://www.moparaction.com/tech/archive/disc-main.html
Offline 72bluNblu
« Reply #9 on: July 02, 2013 - 05:45:22 PM »
Except that there is absolutely nothing wrong with using F/M/J spindles. They're in every junk yard, and work just fine. The bit about "over-angling" the ball joints is complete and total  BS. In fact, there's a strong argument that using F/M/J spindles has a positive effect, especially for those using wider tires with more modern compounds- they improve the camber gain of the suspension.
Don't take my word for it...
http://www.moparmusclemagazine.com/techarticles/suspension/mopp_0503_swapping_a_and_b_disc_brake_spindles/
Ehrenburg just hates everything not perfectly stock. Brake hose routing issues? Give me a break. Just use the hoses from the later cars, which rear-mounted the disks. Bill Reilly wrote the second article showing the F/M/J spindles are just fine, he knows more than a few things about suspension geometry, given that he designed the AlterKation suspension.
Doesn't your '73 Cuda already have disk brakes? If it does, all you need to upgrade to 11 3/4" rotors on the front are new caliper brackets. Do you have pin or slider style calipers? If you've got sliders, you can buy the 11 3/4" caliper brackets from Dr. Diff. If you've got the pin style, shoot me a PM. I have some 11 3/4" pin style caliper brackets that will let you bolt on a set of 11 3/4" rotors. Nice braking upgrade without even changing the calipers.
« Last Edit: July 02, 2013 - 05:52:23 PM by 72bluNblu »
Offline RCCDrew
« Reply #10 on: July 02, 2013 - 09:44:07 PM »
Thanks all for the replies. I'll check out the calipers and get back with you.
Offline RCCDrew
« Reply #11 on: June 27, 2014 - 10:08:23 PM »
Got my big brakes on tonight!  Thanks again for the help!
« Reply #12 on: June 27, 2014 - 10:17:12 PM »
so what did you use for the upgrade ?
Offline RCCDrew
« Reply #13 on: June 27, 2014 - 11:18:28 PM »
I went the easy route and bought some used caliper adapters online. Then I bought the drilled and slotted rotors, bearings and seals from rock auto. Cost about $370 total.
By the way, still have the Charger?
« Reply #14 on: June 27, 2014 - 11:20:48 PM »
yup I do .
