Author Topic: Gauge or sending unit not working?  (Read 620 times)
Offline Mopar Thunder
« on: July 01, 2013 - 12:51:11 PM »
I just installed a new set of aftermarket gauges and a new fuel sending unit.  I have a fuel cell in the car. Problem is the fuel level gauge doesn't read past 1/4 tank even when there is more fuel in it.  This is the 2nd sending unit I put in it. The first one wasn't the correct length, the new one is supposed to be. Which is the best way to check accuracy of both?
Offline dutch
Re: Gauge or sending unit not working?
« Reply #1 on: July 01, 2013 - 05:19:19 PM »
do your ohms for sender and gauge match?
*** Bart ***
« Reply #2 on: July 01, 2013 - 06:27:24 PM »
They are supposed to match, 73-10, but the gauge came in the pod.  Is there a way to check the gauge for the correct ohms?
« Reply #3 on: July 02, 2013 - 03:48:09 PM »
I tested mine by using a variable resistor (pot) in place of the sender and proved out my gauge by varying the resistance between 10 and 80ohms.
« Reply #4 on: July 05, 2013 - 11:06:41 AM »
Thanks, I'll try that when I get home, I am currently at the beach. :cheers:
Offline 67vertman
  • Member since 9-23-2005
« Reply #5 on: July 05, 2013 - 11:11:52 AM »
What are you doing at the beach, when you could of had a four day Mopar work fest?  :poopoke:  :misbehaving:  :smilielol:
Enjoy the water, and body watching.
