Author Topic: Small Block Motor Mount Bolts  (Read 484 times)
Offline daveh
« on: July 01, 2013 - 03:44:32 PM »
Hey guys,
Does anyone know what size motor mount bolts I need for my 71 Challenger 340 small block and how many?  I'd like ARP or something strong.  I know grade 8 is preferred.  I'd like stainless but I'm not sure stainless are going to be strong enough.  What are your thoughts?  Thanks
Re: Small Block Motor Mount Bolts
« Reply #1 on: July 01, 2013 - 08:41:16 PM »
Which bolts ? Mount to block or the cross bolts through the mounts either way I use grade 8 , stainless can gall the threads .
Offline daveh
« Reply #2 on: July 03, 2013 - 04:28:33 PM »
I want to get both sides.  The K-member and engine side.  My was just thrown together and I want to make it correct.  I hate doing things half way.  Thanks
« Reply #3 on: July 03, 2013 - 09:47:59 PM »
the block bolts are 7/16" & vary in length depending on the thickness of the block ear they go through , , the factory bolts are fine thread & use a lock nut to keep them from vibrating loose .
The mount crossbolts are larger / longer , the factory bolts have a tapered end so they start easily , , I think they are 3.5" long , they may be 7/16 thread too ?
