Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Radiator hose inner spring
« previous
next »
Print
Pages: [
1
Author
Topic: Radiator hose inner spring (Read 1927 times)
7212Mopar
Full Member
on:
July 02, 2013 - 05:59:31 PM »
I got new Goodyear replacement radiator hoses for my 73 Challenger. There is no inner stainless steel spring inside the lower suction hose. I took the old one off and there is no spring inside either. Is a small block 340 suppose to have internal spring at the lower radiator hose? May be the 1 inch bypass is sufficient such that the pump will not dead head and collapse the suction hose? I am thinking may be to find a thin piece of rigid plastic pipe and insert it to the hose. What is the typical suction pressure from a stock water pump?
Logged
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ, 6 spd
4Cruizn
Administrator
C-C.com Expert
HEMI FISH
Re: Radiator hose inner spring
Reply #1 on:
July 02, 2013 - 06:22:44 PM »
I would put one in there anyways. I needed some for my big block and bought one on the market for a mustang . . . . Actually I needed two of them and it worked out fine . . . . They were like 5 bucks each.
Logged
7212Mopar
Full Member
Reply #2 on:
July 02, 2013 - 07:58:12 PM »
Agree that it make sense to put it in and won't hurt. My new Challenger has it.
Found the Mustang springs and is under $6 but minimum order is $20 plus shipping. I think I will find some heavy gauge stainless steel wires and make my own. The plastic is definitely a dumb idea (what was I thinking).
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
July 03, 2013 - 12:17:10 AM »
I have rolled up wire coathangers in the past
Logged
72bluNblu
Sr. Member
Reply #4 on:
July 03, 2013 - 01:22:51 AM »
I've run my challenger over 40k miles without them, never had any kind of issue. The springs that came out of the old hoses definitely weren't stainless steel either, they were a rusty mess.
Logged
dutch
Sr. Resident
Reply #5 on:
July 03, 2013 - 02:49:52 AM »
I used 1/8 welding wire. Roll it around a pipe and you have your spring
Logged
*** Bart ***
dodj
Sr. Resident
Reply #6 on:
July 03, 2013 - 11:47:50 AM »
Springs are just a flow restriction IMO.
Logged
1973 Challenger 440 4 spd
73EStroker
Sr. Member
Reply #7 on:
July 29, 2013 - 01:24:41 PM »
Most likely the only way it would collapse is because your rad would be plugged. Then you have bigger problems.
Logged
Barry (Salmon Arm)
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
