Author Topic: Rear seat removal  (Read 820 times)
Offline dvldwg89
  • Semper Fi
Rear seat removal
« on: July 03, 2013 - 12:35:17 AM »
Got my from seat out OK. Now I want to remove the rear seat to look for other build sheets. Are there any bolts holding the rear seat? :popcorn:
Re: Rear seat removal
« Reply #1 on: July 03, 2013 - 12:51:13 AM »
There are brackets welded to the floor. Parts of the seat bottom clip into the brackets. Push down on the front of the seat while also pushing back. Do this on both sides.
The seat back uses two screws to hold the lower section inplace.
Offline dvldwg89
  • Semper Fi
« Reply #2 on: July 03, 2013 - 01:15:11 AM »
Still confused. I understand about the brackets and the push method. You say the seat back has two bolts. Do you remove these bolts before pushing down and back? Or are you saying once I get it off the brackets and out that 2 bolts hold the seat backing on?
« Last Edit: July 03, 2013 - 03:19:27 AM by dvldwg89 »
Offline dutch
« Reply #3 on: July 03, 2013 - 06:16:44 AM »
seat first, then you have access to the bolts that hold the lower part of the seat back
*** Bart ***
Offline dvldwg89
  • Semper Fi
« Reply #4 on: July 03, 2013 - 07:42:55 PM »
Right on thank you guys. :drunk:
