I don't have a clue what "110-114 cl" means. Any chance you could make it really easy for me and tell me what would be a good sounding cam for a 4-speed 383 and the proper carb for it ?
I have a 600 Eldebrock presently and have been planning to changing to a bigger one, but didn't want to buy one until I knew what cam I was getting.
I would suggest this as the cam you would be best to use for what you are trying to acheive
HUG HEH1523BL3
HYDRAULIC CAMSHAFT 112º LSA+3
FLAT TAPPET HYDRAULIC / THREE BOLT TIMING GEAR
$199.00
Flat Tappet Hydraulic / Three Bolt Timing Gear. Light car, mild street: medium to heavy towing or RV. Dual exhaust or headers, 4 bbl carb. Street gearing 3.00 to 3.55:1. 150psi suggested cylinder pressure. Good idle, resto/cruiser. Hot daily driver, mileage OK.
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .470"
.506"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .501"
.539"
Intake Duration at .050"
Exhaust Duration at .050" 215°
223°
Lobe Separation Angle 112º
Intake Opening at .050"
Exhaust Opening at .050" -1.5° BTC
46.5° BBC
Intake Closing at .050"
Exhaust Closing at .050" 36.5° ABC
-3.5° ATC
Min. Suggested Cylinder PSI 155
Sweet Spot RPM 1200 - 4800
Power Ranges: These are the "sweet spot" in the power range. Generally we suggest shifting at 300-500 RPM above the "sweet spot" for the best ET’s.
Spring Warning: Our camshafts are not comparable to other manufacturers and require special valve spring pressures to operate and live satisfactorily. ONLY USE springs meeting the specifications listed here or on the provided cam cards. Valve spring pressures and installed heights are supplied with each camshaft.
Caution: Minimum piston-to-valve clearance is .060" intake and .100" exhaust. If your clearance is not adequate, we have tooling to cut deeper valve reliefs. Check our tooling section or call us. Maximum lift with stock guide height is 0.450", more lift requires shortening the valve guides.
