Motor Mounts Question
Author Topic: Motor Mounts Question  (Read 2212 times)
Offline daveh
« on: July 05, 2013 - 11:44:25 AM »
What are you guys using for motor mounts.  The traditional rubber or polygraphite type mounts?  Mine is a stock application on the 71.  Thanks
Offline Katfish
  • 70 Challenger
Re: Motor Mounts Question
« Reply #1 on: July 05, 2013 - 05:49:59 PM »
 :popcorn:  Curious too
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #2 on: July 05, 2013 - 05:51:36 PM »
I got traditional rubber mounts
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline 06Daytona
« Reply #3 on: July 05, 2013 - 06:29:17 PM »
I used regular mounts but I drilled a 1/4 inch hole through them and used a grade 8 nut and bolt to keep them together. I forgot to take pics when I did it
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline Jesus H Chrysler
« Reply #4 on: July 05, 2013 - 07:19:35 PM »
Not a bad idea!  I've ripped up almost every drivers side mount I've ever had in a big block (usually assisted by being oil soaked and rotted)  That sounds better than what I was going to do, make a solid steel drivers side mount.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline BIGSHCLUNK
« Reply #5 on: July 05, 2013 - 10:33:57 PM »
Schumaker........ no issues........  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #6 on: July 06, 2013 - 08:04:07 AM »
I use magnum mounts. Ever since I tore a stock one. They have a bolt thru the centre to limit movement under accel.
http://chucker54.stores.yahoo.net/maheduenmo.html
Offline KillerBee
« Reply #7 on: July 06, 2013 - 10:39:24 AM »
There are a few options and I've used most with good results.
-I've used solid mounts both sides on a street/strip car.
Shook the car pretty good but still was not unbearable.
-Solid mount on the drivers side and rubber on the passenger
Less vibration and good support especially for high torque big blocks and 4 speeds.
-Set of cheap rubber mounts with good torque strap
-For my current setup I bought a set of Mity mounts from Dynatech
http://www.mitymounts.com/chrysler.htm might be the same thing Mancini is selling definitely the same thing 440source sells.
These mounts have internal locks.
First set I got made the engine sit tilted in the car, Dynatech immediately set a new set which worked after some modifying/tweaking.
Nice mounts but they still let the engine move too much in my 440 Sixpack 4 speed Challenger and actually caused the clutch linkage to flex and bind during hard acceleration.
I ended up adding a torque strap to calm things down.
« Last Edit: July 06, 2013 - 10:52:32 AM by KillerBee »
« Reply #8 on: July 07, 2013 - 08:12:33 AM »
I spent large for the poly mounts which I am told still fail so might as well use the rubber mounts & put a steel strap across from the block to the center bolt to prevent failure
