Author Topic: How to install sound deadener?  (Read 8168 times)
Offline Katfish
  • 70 Challenger
Re: How to install sound deadener?
« Reply #15 on: July 06, 2013 - 12:33:35 PM »
Thx for the info, 2 questions:
- Where did you get the 100sq ft deal?
- What / how do you heat?  The metal or the material?
Thx
Offline shoooter
« Reply #16 on: July 06, 2013 - 01:43:45 PM »
Thx
You heat the material , make sure the metal is cleaned with something alcohol based, wear gloves. I used rubber gloves. I found it easier to use a soft sewing tape measure to fit in all the groves so you get the right measurement. To make templates I used the paper backing off the ones already installed. Still not sure how I'm going to do the doors.
Here is the deal. http://www.ebay.com/itm/FatMat-100-SqFt-Sound-Control-Deadener-For-Cars-Trucks-Free-Dynamat-Sample-/190736900731?pt=Car_Audio_Video&hash=item2c68ce227b&vxp=mtr
Offline HemiOrange70
« Reply #17 on: July 06, 2013 - 04:05:47 PM »
I used dynamat and bought it on ebay-i used two rolls but did not do my roof as someone stated ihe glue could fail with heat and fall down(???) I butted the joints and did not cover the vertical brackets, just the horizontal ones. I installed the floor plugs first as water shouldn't be an issue with these cars (as they are not driven daily-winter-rain etc) in the heat the should be flexible but i used a hairdryer on the mat (foil side) to make it more plyable. I used bubble wrap insulation on the doors and headliner as it was lighter ( stuff used for heat ducts in homes) hope this helps
Offline 500Stroker
« Reply #18 on: July 06, 2013 - 06:25:27 PM »
I did mine in the summer.  The heat of the summer was enough to make the fatmat soft, flexible and tacky.
Offline CudamanTom
« Reply #19 on: July 06, 2013 - 06:26:33 PM »
I'll be installing sound/heat barrier material myself soon so this is a good read and love the info everyone is inputting.
thanks guys.  :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Fern
« Reply #20 on: July 06, 2013 - 07:18:56 PM »
I installed sound deadener in the cabin floor. I just used a heavy mill plastic on the doors and attached it by using double sided duct tape.
I have a convertible so I didn't do the trunk. I will see how it goes and install If  needed.
Offline shoooter
« Reply #21 on: July 13, 2013 - 02:27:08 AM »
 :feedback: do you usually do the roof? This stuff sticks very well and I'm heating it up first so the bond is good. I have heard people say it peels down? My car is black so I'm worried about it getting soft when the car sits outside at a show or something. Does the roof even need to be done?
Offline usraptr
« Reply #22 on: July 27, 2013 - 09:59:12 PM »
To answer your question I don't think most people use it on the roof as they are afraid of it getting hot and sort of melting.  My car is also black.  I just used the stock type insulation on the roof.  I think that will be more than adequate.
For those looking for a good price on DynaMat, try Summit racing.  They have some of the best prices around.  :2thumbs:
(Edited 8-1-17)
Offline shoooter
« Reply #23 on: July 29, 2013 - 03:56:37 PM »
I have talked with a few other members and they have done the roof also. My car will be stored in my shop so I don't have to worry too much a out it getting too hot. I will also be doing my roof
Offline cordodge
« Reply #24 on: July 29, 2013 - 04:52:10 PM »
when i did mine i went a little crazy i put it everywhere from the bottom of the front window to the back glass. also the doors just behind the panels all of the roof and the package tray. i think i went thru 4 and a half boxes of dynamat. did not get a chance to drive it yet but the doors shut like a new 300c and it seems to just firm the body up quite well, im sure i added quite a bit of weight but thats how i pleaded my case to the better half for the 572 hemi  lol.   thx bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline IB-Cuda
« Reply #25 on: August 14, 2013 - 08:53:38 PM »
Guy's,
Just a suggestion... Hoome Deepo sells an sticky alum foil covered insulation pretty cheep. Used a couple of rolls on my son's Torino.
If your on a budget this stuff works really well at a fraction of the Dyna mat cost :money:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #26 on: August 14, 2013 - 09:23:52 PM »
Hey shooter do u have pics of your sound deadened install?
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline Katfish
  • 70 Challenger
« Reply #27 on: August 14, 2013 - 09:37:33 PM »
Guy's,
Got any more info, brand name, where in store?
Offline IB-Cuda
« Reply #28 on: August 19, 2013 - 02:40:14 PM »
I find it in the heating (ducts ect) section, its about 15 bucks a roll and roll is 1.5 ft by 10 or 15 ft if I remember right. its basicly a tan colored foam insul stickey on 1 side and alum foil on the other.
Offline dvldwg89
  • Semper Fi
« Reply #29 on: August 30, 2013 - 04:08:40 PM »
Great post. I will be buying and installing a new carpet this fall/ winter. Great information here, thanks everyone. :2thumbs:
