Author Topic: rear end gear  (Read 1467 times)
Offline pink panther
rear end gear
« on: July 05, 2013 - 08:13:06 PM »
I read on here before that you can spin your rear tire and count the drive shaft rotation to tell what gear is in the car, I always suspected a very low gear based  on RPM at highway speed. I decided to jack up the rear end while I was changing the oil todAY. drive shaft turned 3 3/4 times t0 4 times per one full turn of the rear wheel. what do you think the gear is?
Re: rear end gear
« Reply #1 on: July 05, 2013 - 09:11:52 PM »
Is it an 8 3/4 Mopar rear?   if so 3.73 is closest......Dana rear lists a 3.73 also
I had performed this test more than once & also calculated based on RPM at speed & was convinced I had 3.55s, turned out to be 3.23s  :dunno:
« Last Edit: July 05, 2013 - 09:13:55 PM by Bullitt- »
Re: rear end gear
« Reply #2 on: July 05, 2013 - 09:36:55 PM »
Yes 8 3/4
Re: rear end gear
« Reply #3 on: July 06, 2013 - 05:49:53 PM »
was the other tire blocked or on the ground so it would not move
do you have a sure grip ?
 did both tires turn equally ?
Re: rear end gear
« Reply #4 on: July 06, 2013 - 06:00:49 PM »
Both tires off the ground, yes it sure grip
Re: rear end gear
« Reply #5 on: July 06, 2013 - 10:40:11 PM »
as long as both tires do not hang up on the brakes & turn easily it should be accurate , if it is exactly 3.75 turns it will be 3.73 which is not available from Moper only aftermarket , if it is closer to 4 turns I would bet on 3.91 ratio .
