Author Topic: Setting Timing  (Read 865 times)
Offline cudabob496
Setting Timing
« on: July 06, 2013 - 08:46:21 PM »
Anyone got a method for setting timing when you are alone, want to use a dial-back light, and need the rpm
up around 3200 rpm. Guess I could make a metal hook that holds the throttle open a fixed amount?
2011 Kawasaki Z1000
Offline high perf mopar
Re: Setting Timing
« Reply #1 on: July 06, 2013 - 09:51:11 PM »
i set up the timing light and lay it on the passenger fender,then start it up.left hand timing lite,right hand long screw driver to increase the RPM's...one with a notch in it helps for the throttle shaft.
no need to try and get it dead on anymore with the MSD adjuster mounted next to the shifter.just really close.
u may have to set it down and adjust whatever u need while doing it,but thats what the fender covers r 4..
looking forward to playing with my MSD adj timing control...its set within the ball park like all motors r..really crisp throttle response when cranking it up..marked at 32.on the adj....for whatever thats worth,meaning my setup...
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline cudabob496
Re: Setting Timing
« Reply #2 on: July 07, 2013 - 12:21:29 AM »
thanks, that's a plan!
ya, if its not at 36, say at 34, I will just add 2 degrees with the dial inside the car!
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
Re: Setting Timing
« Reply #3 on: July 07, 2013 - 02:23:37 PM »
I just stick a nickel, or such, between the throttle screw and lever
Re: Setting Timing
« Reply #4 on: July 07, 2013 - 10:17:54 PM »
Turn up the idle screw or use the fast idle cam if you have a choke circuit .
Offline cudabob496
Re: Setting Timing
« Reply #5 on: July 07, 2013 - 11:59:34 PM »
thanks, ya, put a washer under idle screw, and it held steady at 3500 rpm. guess I don't have to call
the ex wife over after all!
Question, timing was 37 BTDC. Is 36 where it should be, or can you go higher as long as you don't ping?
Or is every engine unique?
After checking timing, it sure was nice to just dial back the adjustable timing knob 1 degree, rather than wrestle
with the distriubutor.
didn't realize the idle adjust screw could take an engine up above 3 or 4000 rpm! Maybe to redline!
« Last Edit: July 08, 2013 - 02:01:47 AM by cudabob496 »
2011 Kawasaki Z1000
Re: Setting Timing
« Reply #6 on: July 08, 2013 - 08:50:13 AM »
every engine is unique , depends on the speed of the burn , some make the best power around 32* others closer to 38*
