Author Topic: Installing Drivers side mirror  (Read 722 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: July 06, 2013 - 11:21:26 PM »
I bought a mirror kit with the hardware and nuts to shrink up the T nut when you tighten it. The only problem is that you cant get behind the plate in the door to put the nut on the screw. The mirror is a remote mirror. Anyone one else have this issue?
Offline 72cudamaan
Re: Installing Drivers side mirror
« Reply #1 on: July 07, 2013 - 08:59:32 AM »
I have the tool for doing just that. But without it, how about a pair of 12" long bent nose pliers? You
can get them at a hardware store usually, or Harbor freight carries them.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline filmsurgeon
« Reply #2 on: July 07, 2013 - 04:33:27 PM »
Check this out for how to install driver's/passenger's mirror.
http://www.hamtramck-historical.com/mirrors.shtml
Offline 72cudamaan
« Reply #3 on: July 07, 2013 - 05:38:08 PM »
That's the tool I have, but the OP wants to know how to do it with a screw and a nut.
« Reply #4 on: July 09, 2013 - 08:30:42 AM »
Very interesting! Thanks! I may go that route. That looks way easier.
Offline 72cudamaan
« Reply #5 on: July 09, 2013 - 08:49:52 AM »
Are you going to Carlisle? I could bring the tool for you to borrow.
« Reply #6 on: July 09, 2013 - 09:55:05 PM »
I wish I was. Thanks for the offer though.
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: July 09, 2013 - 10:04:06 PM »
That is an interesting tool . . . Would that work on a passenger door that has never had a mirror?    :clueless:  is there something on the inside of the door that helps support the mirror?   :dunno:
Offline 72cudamaan
« Reply #8 on: July 09, 2013 - 10:28:48 PM »
Dave, the tool is like a pop rivet gun. You thread a nutsert onto it. stick the nut in the hole and squeeze. I'll show it to you tomorrow when you come by.
