Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Power steering pump replacement questions
« previous
next »
Print
Pages: [
1
Author
Topic: Power steering pump replacement questions (Read 645 times)
Kevin71
Full Member
on:
July 07, 2013 - 07:06:59 PM »
Power steering pump I have came from auto zone a few years ago. Probably don't have 5,000 miles on it and it's leaking. I would like to put a good one in and not have to do this again. Any opinions on different brands and how well the hold up. It's a saginaw style on a 440.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Power steering pump replacement questions
Reply #1 on:
July 07, 2013 - 11:16:09 PM »
Where is it leaking ?
You can get an Omega seal kit for $20 I easily install most of the seals
Logged
Kevin71
Full Member
Reply #2 on:
July 09, 2013 - 02:38:09 PM »
I tried seperating the tank from the pump on the last one I replaced. I couldn't get it apart. This one is leaking between the tank and the cast iron pumb on the front. I believe. Only place I can fluid is at the base of the pumb at the front it's wet
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
July 11, 2013 - 01:25:13 PM »
there are 2 or 3 bolts to remove that hold the housing on including the pressure hose fitting the pump should slide out of the housing , make sure the housing is not bent or deformed , there is 1 large o ring around the pump
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
