Author Topic: Potential pinch in the oil pan seal?  (Read 684 times)
Offline Tonker1
« on: July 08, 2013 - 09:44:14 PM »
My new QuickTime bell and scatter shield install has been held up by two rubber lumps at the back of the oil pan, as in the photographs bellow. I'm assuming this rubber comes from the half moon rubber oil pan gasket.
Ideally I'd like to just cut the lumps off or sand them back, working under the assumption that its just excess gasket which has been pushed out of the oil pan to engine block interface.
I'm just wondering if the gasket could have been pinched, such that if I cut off the excess all of the engine oil will come flooding out?
Is a pinch in that location even possible?
Any info would really help as I'm currently waist deep in a transmission swap!
Offline 72cudamaan
Re: Potential pinch in the oil pan seal?
« Reply #1 on: July 08, 2013 - 09:55:55 PM »
Usually that portion of the gasket (the rubber 1/2 circle) has a large overhanging lip to the outside. I
would think you could carefully trim it with a razor blade.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Tonker1
« Reply #2 on: July 09, 2013 - 02:18:54 AM »
Cutting it back worked perfectly, there is no leaks or seams where a pinch would have been!
The scatter shield is now on and I've started dialling the bell
Offline 72cudamaan
« Reply #3 on: July 09, 2013 - 08:54:36 AM »
 :2thumbs:
