Author Topic: Pilot Bearing  (Read 637 times)
Offline dana60
Pilot Bearing
« on: July 11, 2013 - 04:51:10 PM »
Does any one know where I can get a Pilot Bearing ( not bushing ) for a 440 engine? I have looked at all the local auto parts stores but they can only find the bushing type. A part number would be great as well, thank you all in advance for your help!!
 :wavingflag:
Offline 70CUDA4SPEED
Re: Pilot Bearing
« Reply #1 on: July 11, 2013 - 04:53:44 PM »
Re: Pilot Bearing
« Reply #2 on: July 11, 2013 - 10:49:30 PM »
If you switch to this type instead of the bushing, does the end of the crank have to be machined for it to fit?
Re: Pilot Bearing
« Reply #3 on: July 12, 2013 - 09:01:53 PM »
Sometimes as the nose of the pilot shaft will still bottom out , you can easily drill the hole deeper though as it doesn't have to be centered
