Author Topic: Best method to pull yolk off pinion during seal replacement  (Read 1232 times)
Offline bucknbass
« on: July 16, 2013 - 02:03:17 PM »
Replacing the pinion seal on my 489 case and having issues removing the yolk.  Nut came off no problem - yolk, not so much.  Appreciate any tips or tricks to helping it slide off the pinion.
Offline j72440rallye
Re: Best method to pull yolk off pinion during seal replacement
« Reply #1 on: July 16, 2013 - 08:45:03 PM »
I was able to free mine with light pressure from a harmonic balancer removal tool while tapping the aft surface of the yoke corners.  This took a while  but I was worried anything more aggressive could damage the pinion or its bearing.
« Reply #2 on: July 16, 2013 - 09:57:51 PM »
You are planning on replacing the crush sleeve right?
« Reply #3 on: July 17, 2013 - 12:28:16 AM »
or you at least marked the nut & pinion so you know exactly where it was originally ?
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #4 on: July 17, 2013 - 08:07:37 PM »
I supply a yoke puller for all American 55-89 Rear wheel drive cars and trucks http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
Offline bucknbass
« Reply #5 on: July 17, 2013 - 09:04:18 PM »
Wasn't going to replace the crush sleeve but I did mark the pinion and nut and also know the preload since I checked it with a torque wrench.
Offline bucknbass
« Reply #6 on: July 17, 2013 - 09:07:01 PM »
Thanks John.  I've got one puller to try.  If I can't get it off with that I'll order yours.
