Author Topic: something new  (Read 630 times)
Offline rattlesnake
  • Rattlesnake
something new
« on: July 16, 2013 - 11:38:42 PM »
Heres one for ya. A 1972 Dodge that will start, but when I release the key to the run positios it dies. If I hold the key forward so that it is halfway between run and start it will stay running but dies when it is released. I put a new electrical ignitionswitch in the column assuming it was wore out, did not fix it.. Could something be wore out in the key switch?  Does anybody have any ideas?
keep honking I'm reloading
Re: something new
« Reply #1 on: July 16, 2013 - 11:45:23 PM »
You probably have the dual ballast resistor & the run side is bad, just a bad ballast if it's the single style OR the wiring for the run power (blue) is bad/has poor connection somewhere along the way.
  Seen it here many times.
« Last Edit: July 16, 2013 - 11:47:46 PM by Bullitt- »
Offline rattlesnake
  • Rattlesnake
Re: something new
« Reply #2 on: July 17, 2013 - 12:03:34 AM »
Where would the resistor be located on the car? I think I know what it looks  like as my Cuda has one on the firewall. Is this the same type of thing u are talking about?
Re: something new
« Reply #3 on: July 17, 2013 - 12:30:32 AM »
usually on the firewall near the wiper motor , white ceramic block
Offline rattlesnake
  • Rattlesnake
Re: something new
« Reply #4 on: July 18, 2013 - 12:19:49 AM »
ok thank you guys. Love this site.
