Author Topic: Ford Motor Sports Speedometer gear recommendations needed  (Read 1847 times)
Offline DocMel
« on: July 17, 2013 - 09:06:52 AM »
Im running a new Keisler.  It currently has the orange speedo gear.  Problem is that my Speedometer reads 50 mph when I am actually traveling 62 mph.
Could anyone recommend the teeth/color speedo gear I need to get my actual speed readings closer to being accurate?
Re: Ford Motor Sports Speedometer gear recommendations needed
« Reply #1 on: July 17, 2013 - 09:43:25 AM »
your speedo gear has too many teeth & is turning too slow , you want approx 18% less teeth , not sure how many you have now though
Offline DocMel
« Reply #2 on: July 17, 2013 - 01:10:42 PM »
Chryco
I now have 19 gears  (I actually have the pick gear at 19 teeth, not the orange gear)
So I am assuming, if I need 18% lees total teeth, the math basically ends up to 17 teeth? now needed
« Reply #3 on: July 17, 2013 - 03:04:44 PM »
By my math you need the speedo to turn more than 20% faster so 50 x1.2 is 60 mph so if you reduce the tooth count by 20 % would be 3.8 teeth you want it to turn a bit fasterthen that so I would start with 15 teeth
Offline DocMel
« Reply #4 on: July 17, 2013 - 05:10:58 PM »
Right   Got ya, thanks.  All the websites appear to have the 16 teeth as the smallest available.  I may have to go with a 16 and bear with it
« Reply #5 on: July 17, 2013 - 06:00:12 PM »
I have a keilsler kit and my speedo is off by about 20 mph too. Could you post a picture of the gear ? Mine was black?
Offline Travis72
« Reply #6 on: July 18, 2013 - 01:29:11 AM »
Use this calculator with your tire size and gear ratio:
http://www.5speedtransmissions.com/calculators.html
Brad, this is what the gear looks like along with some of the various size options:
http://www.ebay.com/itm/5-FORD-SPEEDOMETER-GEAR-MANUAL-TRANSMISSION-/221080239706?pt=Motors_Car_Truck_Parts_Accessories&hash=item337968be5a&vxp=mtr
Travis
72 Cuda
« Reply #7 on: July 18, 2013 - 07:38:13 AM »
Travis
72 Cuda
Thanks ! That's it!  :2thumbs: I think I'll just buy the e-bay gears instead of dealing with Keisler again.  :pullinghair:
Offline DocMel
« Reply #8 on: July 22, 2013 - 09:27:44 AM »
Thanks Chryco.  I placed in the 16 tooth, and all is spot on   $8 fix
« Reply #9 on: July 22, 2013 - 09:33:10 AM »
Awesome  :2thumbs:
« Reply #10 on: July 22, 2013 - 05:36:36 PM »
 :clapping:  Thanks for posting this other wise I never would have know what the speedo gears were from! :2thumbs:
« Reply #11 on: August 01, 2013 - 05:11:52 PM »
Travis
72 Cuda
Thanks again Travis and DocMel  :wave:  I bought that kit in the e-bay link , just installed the pink one so I hope it's all good now! Going out to a local cruise night tonight to test it out! :worshippy :clapping: :2thumbs:
For the record Keisler modifies/welds the tailstock in there auto OD A-41 kit and used Ford manual speedo gears. ( thought I'd mention that if someone down the road is searching the net for info)
« Last Edit: August 01, 2013 - 05:17:46 PM by brads70 »
