Author Topic: Painting new gas tank  (Read 3455 times)
Offline shadango
« on: July 17, 2013 - 07:37:36 PM »
So what have yinz used to paint your (new) fuel tanks before installing?
I picked up a spectra at Carlisle and its raw steel.   Dont want itt o rust, so figured I would paint it.
I have some of the stainless steel paint left over from painting my LCAs a while back....that would help stave off corrosion right? Can I paint black over that?  Not sure I want a silver tank drawing attention....
What was the "stock" color?  My old tank is black, painted by the body shop that did the car....
Offline 72cudamaan
Re: Painting new gas tank
« Reply #1 on: July 17, 2013 - 10:16:40 PM »
I think "natural" unpainted was original. How about some galvanized paint. Then paint over the top if desired. Or
epoxy primer then your color of choice.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: July 17, 2013 - 10:26:52 PM »
RPM from ECS.
« Reply #3 on: July 17, 2013 - 10:33:46 PM »
I always thought they were galvanized steel....manufacturers site states rust resistant, some forums refer to them as being galvanized. If this is true there would be no need to paint but if you do it will need special preparation. http://tlc.howstuffworks.com/home/how-to-paint-galvanized-metal.htm
« Reply #4 on: July 17, 2013 - 11:26:26 PM »
Do not paint it. It will look like you painted an old crusty tank. They look great the way they come. I've heard people just wipe them down with WD-40 every once in awhile. RPM would also work great.
Even if you don't do anything, it will still look new for a long time. Salt exposure is what will change the appearance. Don't drive it in the winter.
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: July 18, 2013 - 12:06:54 AM »
I put a coat of clear on my new tank prior to installation . . . I wanted something on it to help resist rust.   :cheers:
Offline spamtank
« Reply #6 on: July 18, 2013 - 08:58:29 PM »
I tried to apply clear as well.  I wiped the tank down about 4 times with lacquer thinner.   It ended up peeling before the end of the summer.
I'm thinking RPM will be my next attempt.  I applied that to some of my suspension parts on the new challenger using a heat gun to liquefy it and get it to flow.  Not too thrilled about heating the gas tank.  I actually heated the surface of the RPM product in the container and used a rag to apply it from there.  That didn't work too badly, and should work okay for the gas tank.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline 72cudamaan
« Reply #7 on: July 18, 2013 - 09:50:23 PM »
[/quote]
I tried this method on some parts. They are still sitting a plastic coffee can with rust forming on them. I glass beaded the parts first
so I know there was no rust when I applied the stuff. Not very impressed.
Offline anlauto
« Reply #8 on: July 18, 2013 - 09:54:54 PM »
I've never painted a new tank nor have I ever had problems with them rusting. :2cents:
« Reply #9 on: July 18, 2013 - 10:20:23 PM »
When you heat the part and then apply the RPM, it melts down into the pores.  If you heat the RPM and wipe it onto a cool surface, you are just applying it to the highest spots.  Rust will form in the low spots and continue to grow.
Offline shadango
« Reply #10 on: May 16, 2015 - 09:27:49 PM »
SO I know this thread is a couple years old....that is because I FINALLY got around to swapping the new tank in.  LOL :cooldancing:
Decided to install as-is, no coatings.  Turned out nice.....and no leaks from the reinstalled sender gasket which I was fearing...SOOOOO much easier  to install that sender when the tank is on a table in front of you, but even then tricky......and I had the benefit of the special lock ring tool i bought at Carlisle 2013 as well!
Old one.....
New one
Then washed her down and shined up the new tires........felt good to do some work on the fish after a long drought last year!!!!!!!
