Author Topic: ** 72cudamaan AKA .... Andy needs our HELP! **  (Read 61017 times)
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
Re: ** 72cudamaan AKA .... Andy needs our HELP! **
« Reply #45 on: July 22, 2013 - 07:23:12 PM »
I also have small block torsion bars
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #46 on: July 22, 2013 - 07:47:29 PM »
I have an oil windage tray that I get add, as well I too have a set of small block torsion bars painted and ready to go.
Offline 72cudamaan
« Reply #47 on: July 22, 2013 - 09:47:39 PM »
Andy can we assume you have the big sector shaft steering box? also, 72 stock size spindles?
I have the 73-74 stock spindles here with the pin caliper bracket for the bigger rotors?
I have the Lokar downshift cable ( just the cable and arm on the tranny) and a 727?
I have a 750 Holley(3310) vac secondary is nothing better comes up?
Brands new in the box PS pump (from local jobber, it looks a little different but works?)
I have a nice drive shaft but it's for a Challenger?  We could get it shortened if nothing else turns up?
I have the brand new in the box 3/8 fuel sending unit with 1/4" return ( new from Roseville) Cuda same as Challenger? :dunno:
I have the old Idler and pitman arms I replaced them when I got my car with the fast ratio ones?
Are you all set for a tranny, rear end, leaf springs etc..? As mentioned I have them too! Leaf springs have hangers and shackles on them too.
 :wave:
I have the large sector shaft steering box and 73-up spindles
I may have found an A518 trans. I'll check if the lokar cable will work
I have a set of leaf springs, but no idea if they are any good.
The fuel sender appears to be the same. Do you have a part # Brad?
I'm not sure on a driveshaft yet, depends on which tranny I end up using?
I'm not fussy about a ps pump as long as it works :)
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72cudamaan
« Reply #48 on: July 22, 2013 - 10:21:40 PM »
I have one spare windshield but it has a birds eye chip near the center, may be repairable.
I have an extra moog idle arm, new in box that is yours now :)
I also have a driveshaft that is yours.
Let me wait on the windshield. I'm afraid of the crack growing.
  :2thumbs: on the idler arm
Have to wait on the driveshaft (depends on what trans)
Using a b/b motor so I don't know if the torsion bars will work or not?
Thank you very much.  :2thumbs:
« Reply #49 on: July 22, 2013 - 10:26:08 PM »
Sending unit says U112C on the box? 3/8" out with 1/4" return
Offline CUDA JAS
  • vroooooom!
« Reply #50 on: July 22, 2013 - 10:39:36 PM »
I have a set of used smallblock torsion bars...no clips or boots.
I think I have a set of tie rod adjuster sleves around here some where, but not sure.
Yours if you need them.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline jimynick
« Reply #51 on: July 22, 2013 - 10:48:21 PM »
Just saw this and words kinda fail me. Where IS Andy? I've a Challenger, so lots of my spare stuff won't work, but if it's possible to send things, then I'll see what I can do. Andy, what's your address- you can PM me if you choose? Ian
« Reply #52 on: July 22, 2013 - 10:51:03 PM »
He is in Ann Arbor MI, I most likely will be driving down with a load of parts , maybe I could take what ever your donating down at the same time?   :dunno:
« Reply #53 on: July 23, 2013 - 12:40:05 AM »
I have a lot of these parts in my Sea container back in AB , I doubt I can get to them though & shipping would be tough , I have a number of starters ,alts, ecu , dist , oil pans , timing covers , 50 pullies ,spare headers , big block T bars & leafs , just not sure how to get them .
Offline 4Cruizn
  • HEMI FISH
« Reply #54 on: July 23, 2013 - 01:32:09 AM »
Yes and he is also 1/2 hour from me so if you need to ship anything or want to donate , I will help as much as I can!
Offline shoooter
« Reply #55 on: July 23, 2013 - 01:52:50 AM »
AB=Alberta? i could get some parts and send them with i will dig up too., I travel across the line and could get a better shipping rate in the states...
Offline Cuda Cody
  • Vancouver, WA
« Reply #56 on: July 23, 2013 - 02:18:57 AM »
I have a lot of pullies so I'll get those out and find a set that will work.
Offline GranCuda1970
« Reply #57 on: July 23, 2013 - 03:39:40 AM »
I got a new idler arm in bag for a cuda some other stuff for a 440 I will look out in the garage and see whats avail from the list.
  I got a 1970 cast waterpump and housing, a small block 340  26" fan shroud that prolly wont fit.
« Last Edit: July 23, 2013 - 06:14:11 AM by GranCuda1970 »
Offline blown motor
« Reply #58 on: July 23, 2013 - 08:55:58 AM »
Brad, when do you think this is going to happen? I'm going to Jackson MI in a few weeks which is just west of Ann Arbor. I can take a bunch of stuff and drop it off. Could also stop at Roseville and pick up parts. I'll be going right past there.
« Reply #59 on: July 23, 2013 - 09:25:38 AM »
If your going in a few weeks that is most likely sooner than I was thinking! :2thumbs:
