Once you get whatever lock that will fit in there, you can install an electronic trunk release from any early Mopar and pop the trunk that way. Volare, Aspen, I think, any high dollar Mopar with a electric trunk release will work. They are cheap. It bolts in with 2 bolts - it replaces the manual trunk release. Direct replacement. Still use your key. or push a button. They are all over on ebay. Just run a wire to it, and put in as many switches as you want. Glove box, center console, and emergency switch in case you get abducted and thrown into the trunk, lol. Any Mopar will bolt right up. You just have to run the wire to it. It really is that simple. 2 bolts and a hot wire. I have one in my Challenger, and one in my Coronet. factory. reliabe. STILL use your key, or push a button. Unbolt old unit. Bolt on new unit, and run wire, install switches. Simple, and cheap. Oh - and elegant! lol.
