Author Topic: manual washer pump question  (Read 1563 times)
« on: July 22, 2013 - 10:31:03 PM »
Ok so I ran all new lines from the washer tank to the rubber foot pump and also new lines up to the squirters? Doesn't work so I assume the foot pump is the issue?  It was never hooked up since I owned the car so I have no idea if it ever worked?
Next step is to remove the foot pump and inspect? Anyone been down this road? Anything to look out for?
 :dunno: :clueless:
Is the foot pump being repopped?
Re: manual washer pump question
« Reply #1 on: July 23, 2013 - 12:22:28 AM »
could be a bad diaphragm or a bad check valve , pressing the diaphragm & blocking the lines it should not expand if it hold vacuum , if the check valve is bad it may be just pushing fluid back & forth
« Reply #2 on: July 23, 2013 - 12:30:34 AM »
Thanks, is anyone making replacements?
« Reply #3 on: July 23, 2013 - 12:42:37 AM »
I think some fords had inline check valves that could easily solve the issue
« Reply #4 on: July 23, 2013 - 07:04:01 AM »
Don't think so.
Offline JayBee
« Reply #5 on: July 23, 2013 - 07:13:11 AM »
Yeah, I've taken mine apart, re-conditioned it and sold it for 5 bucks. Once you get into it you'll figure it out, it's pretty simple.  Neil's already mentioned the main things that could go bad.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #6 on: July 23, 2013 - 09:22:53 AM »
Thanks guys I'm hoping to get some time today to take it out and apart. Member Bullit PM'ed me , looks like the Ford one is pretty close if not the same thing!
Offline anlauto
« Reply #7 on: July 23, 2013 - 11:32:02 AM »
FORD  :22yikes: Might slow your car down :stomp:
Offline GranCuda1970
« Reply #8 on: July 23, 2013 - 11:34:15 AM »
Yeah you don't wanna infect the rest of the car  :grinno:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: July 23, 2013 - 12:21:20 PM »
Or heck you can do what I did, convert to electric!!!
 :thumbsup:
« Reply #10 on: July 23, 2013 - 05:01:11 PM »
Slow down?!?, heck, it won't even start!!   :smilielol:
« Reply #11 on: July 23, 2013 - 05:48:27 PM »
 :lol: :2thumbs:
« Reply #12 on: July 23, 2013 - 08:05:58 PM »
My Bad , no ford parts the engine will distroy itself !!
« Reply #13 on: July 23, 2013 - 09:18:05 PM »
SUCCESS  :2thumbs:   Took me about half an hour to fix it. I figured it's broke, take it apart you can't break it anymore? Turns out from sitting for who knows how many years the valve that consists of check balls in the plastic nozzles was stuck in place with a bunch of "crud" I sprayed it with WD-40 and blew it out a few times to clean it out and it worked again. Lots of crud in the rubber diaphragm too.   I installed it and it leaked between the diaphragm and the check valve  ( I think?) so I disassembled it again and spread some "form a gasket around the rubber parts and reassembled it and installed it again. I'll let it dry overnight and try in the morning.  When assembling it make sure the nozzles are at 90 degrees so the check balls can operate properly.  :swaying:
Offline anlauto
« Reply #14 on: July 23, 2013 - 09:23:35 PM »
Yep...always "check balls" for proper positioning... :roflsmiley:
