Author Topic: So lets start a discussion about small block heads  (Read 16943 times)
« on: July 23, 2013 - 11:20:00 PM »
Who Has the best bang for the $$
 What heads are best for various power levels
 IMO the Eddy heads are just alum replacements lighter but no significant power gains & very poor quality , core shift issues etc .
 I have never used RHS heads .
 I know Indy has Small block heads , never used those .
 I have used the 308 castings to gain 40 RWHP over X heads .
 There is also the magnum heads if you are OK with the Ball Stud rockers but special intake is required .
 I have also used W series heads with awesome results but they are very expensive by the time you factor in special intake , rockers , headers & valve covers over the base cose of the heads alone . The W 8/9 heads are friggin awesome & can make 700+HP but require the R3 block with 6 bolt head mounting .
 So what lies between the basic replacement eddy head & & the all out R3/W9s
 :clueless:
« Last Edit: July 24, 2013 - 12:57:46 AM by Chryco Psycho »
Re: So lets start a discussion about small block heads
« Reply #1 on: July 24, 2013 - 12:15:50 AM »
These guys provide lots of #s for your consideration  http://www.shadydellspeedshop.com/cylheads.htm
« Reply #2 on: July 24, 2013 - 07:56:36 AM »
I was impressed with the flow #'s from these guys?
Airwolf 220
http://www.j-performance.com/index.php?option=com_content&task=view&id=59
Offline Road_Runner
« Reply #3 on: July 24, 2013 - 04:22:50 PM »
I'd like to add the 302 heads to these discussions as I have a set that I may try to use if I do a mild-medium build on my 318.  Can these be cost effectively made comparable to the 308 heads?  What are their limitations on a 318? 340? 348-372 stroker?  How about the J heads if new pistons are used?  It would be very helpful to map out the best HP/RPM ranges that each of these options are best suited for.
This is a great topic as I am piecing together the parts for my engine build.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Cuda Cody
  • Vancouver, WA
« Reply #4 on: July 24, 2013 - 06:08:38 PM »
I'm thinking of building a clone T/A motor with my brother and have an extra 1971 340 block that needs heads.  We just want to make a stock motor.... it will be stock cam, intake and exhaust.  What would be a good head for this clone 340 six pack motor?
Thanks!
« Reply #5 on: July 24, 2013 - 10:23:02 PM »
I would pass on the X&J castings , the 302 are Ok but have a smaller combustion chamber & ports , they will make a lot of torque but will run out of air flow fast especially on a`stroker build.
« Reply #6 on: July 24, 2013 - 10:39:35 PM »
What are core shift issues?
« Reply #7 on: July 24, 2013 - 10:55:17 PM »
I pulled a brand new set of Eddy small block heads out of the box & the ports were cast more than 1/8 closer to 1/4 to one side , I talked to the Mopar salesman there & he went through 16 heads & picked out the ones that were closet to being cast properly for himself out of the batch & said most had bad core shift
Offline jimynick
« Reply #8 on: July 24, 2013 - 11:01:39 PM »
Core shift refers to the sand cores used when the casting is poured and sometimes that sand core moves a wee bit. so you get inequalities in casting thickness, which can be a real pain if you're trying to port/machine them. Capice?  :thumbsup:
« Reply #9 on: July 24, 2013 - 11:07:42 PM »
Core shift is what happens what an engine block, cylinder head, manifold or other type of sand casting shifts in the mold when molten iron or aluminum is poured into the mold.  When core shift happens, it can throw factory machine tooling off, mislocating oil galleys, cooling passages, lifter bores, and even cylinder bores to where wall thickness gets dangerously thin in places.  This isn't as critical with a stock rebuild, but very important if you're going racing.
When you spot mislocated lifter bores and oil galleys, it isn't always core shift.  Sometimes it was miscalibrated tooling as well, but a rare occurance.  Most of the time, it's core shift.  Keep core shift in mind and thoroughly inspect before having expensive machine work performed.
Read more: http://blogs.mustangmonthly.com/6422437/miscellaneous/core-shift-and-how-to-spot-it/#ixzz2a1UDPA8t
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #10 on: July 25, 2013 - 11:01:47 AM »
Airwolf 220
Wow brad! Thanks for the link!  I have been looking for and aluminum head for my chally's stroker build, and I didn't want Eddy's and I didn't want to give up my I take and headers to swap to W style heads.  After seeing what u posted I didn't a lol research and Mopar Muscle had some good things to say about them too!  Thanks again!
Thanks!
I'm with CP on this one, I have J heads only 340 at the moment and they do the job just fine and look the part, but they are nothing special.
« Last Edit: July 25, 2013 - 12:29:15 PM by moparman82 »
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
« Reply #11 on: July 25, 2013 - 11:13:16 AM »
Thks CP, JN, TC.
Capice!  :2thumbs:
« Reply #12 on: July 25, 2013 - 11:19:11 AM »
Thanks!
I would look at the 308 casting if you want it to look stock
Offline Road_Runner
« Reply #13 on: July 25, 2013 - 12:06:08 PM »
Can you tell me exactly what years & motors came with the 308 heads?  I've looked for these, but most heads are not listed as '308' heads.  Will they always have 308 cast into them?  How about part numbers?  Sorry for all the questions, but I'd like to crawl some local junk yards for these and need to know what to look for.
Thanks, Jim
Offline RCCDrew
« Reply #14 on: July 25, 2013 - 12:19:15 PM »
How about the RHS iron heads?
