Author Topic: So lets start a discussion about small block heads  (Read 16947 times)
Re: So lets start a discussion about small block heads
« Reply #30 on: March 15, 2015 - 09:11:24 AM »
yes , go to 2.02 valves , blend behind the seat , create a wing shape around the guide to enhance the swirl & leave a curve from the guide up behind the seat to help curl the air flow
Offline rUNCHARGER
« Reply #31 on: March 15, 2015 - 01:10:45 PM »
I think the Engine Quest or Airwolf are a good direction. We're going to run these on a stock stroke 360, they would be better suited to a stroker though.
Sheldon
Offline RCCDrew
« Reply #32 on: March 15, 2015 - 03:00:19 PM »
What about milling the head .030 to boost compression? I could use it.  Also, what about the pinch in the intake port? Should I work that?
« Reply #33 on: March 15, 2015 - 07:21:45 PM »
Sure you can mill the head , the pushrod bump can be widened but it creates a venturii which increases air flow speed , so I usually widen it some & smooth the curve
Offline RCCDrew
« Reply #34 on: March 15, 2015 - 10:55:30 PM »
10-4. It will be a while but
I'll let you know how it works out. I'm hoping for the same results you achieved.
Offline vinb
« Reply #35 on: March 20, 2015 - 05:54:58 PM »
Is it my eyes or is their a whole bunch of shim under those springs?    :eek4:
Offline rUNCHARGER
« Reply #36 on: March 21, 2015 - 12:15:46 AM »
Yep: We'll go through them, must be the wrong springs.
Sheldon
Offline Mopar Mitch
« Reply #37 on: March 23, 2015 - 11:06:54 AM »
I have a collection of LA 340-360 heads... all iron.. willing to seel them off eventually ...   would like to get light weight aluminum heads that appear stock on the outside (in other words, with the general casting contours and freeze plugs as the cast iron stock heads have)... as the 440-Source BB heads are available... BUT, its my understanding that there are no aluminum SB heads that give that appearance... having the original LA intake ports/shape, same exhaust ports/shape.. as well as bolt pattern.  The aluminum Eddy and other such heads are dead give aways... unless they could be reshaped/recontoured.... has anyone ever done this?  ideas?
Offline soundcontrol
« Reply #38 on: March 24, 2015 - 06:41:53 AM »
Anyone of you small block head gurus that knows the valve stem dia. of a 72-73 360 Head (587 casting). Is the the same for all small block heads?
/ Ken
topic=108917.new#new
Offline AussieMark
« Reply #39 on: March 24, 2015 - 07:06:30 AM »
3/8
« Last Edit: March 26, 2015 - 12:10:53 PM by Chryco Psycho »
Offline aris_unlimited
  • Project in full swing
« Reply #41 on: March 27, 2015 - 03:47:25 AM »
I fully plan to buy some EQ magnum heads for my build. If we're talking aftermarket upgrades I would call them best bang for the buck. Stock, I'd say original magnum r/t heads if you could get a good set.
Cuda is gone :(
74 satellite, daily driver/project now
Offline Denison636
« Reply #42 on: March 28, 2015 - 01:33:38 AM »
I have a set of heads on my motor that I like but don't have much info on.
They were from mopar performance and were a replacement for the 302 fast burn. They came with 2.02 intake and 1.60 exhaust valves. They are also cast iron.
From what I know they stop making them and that circle track guys use to like them.
If you know more please let me know.
Its just a little 340 with a miss
« Reply #43 on: March 28, 2015 - 06:03:36 AM »
Any casting #'s etc...?
Offline Denison636
« Reply #44 on: March 28, 2015 - 11:55:34 AM »
I will write them down next time I have the valve covers off.
