Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Front Crank Seal
« previous
next »
Print
Pages: [
1
Author
Topic: Front Crank Seal (Read 867 times)
gafletch
Jr. Member
Front Crank Seal
on:
July 24, 2013 - 10:52:26 AM »
What's the procedure for changing a leaky front crank seal on a 440, and should I check anything else there? Thanks! Greg in the Sublime Green Time Machine.
Logged
mopardave
Sponsor
Resident
1973 Challenger F8 in and out, 68 383,727 3.23 pos
Re: Front Crank Seal
Reply #1 on:
July 24, 2013 - 08:24:09 PM »
basically have to remove everything from the front of the block to get to the timing cover, seal is pressed in from the inside of the timing cover, good time to check the chain and sprockets if need
Logged
Mopar Dave
Rosevillemoparts.com
if I haven't replied to your post or PM email me direct
dradcliffe@mikeriehls.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
gafletch
Jr. Member
Reply #2 on:
July 26, 2013 - 01:18:55 PM »
Ok thanks Dave.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
July 26, 2013 - 11:51:55 PM »
Often the seal wears a groove in the balancer , it can be replaced or you can install a speedy sleeve on the shaft of the damper .
Logged
gafletch
Jr. Member
Reply #4 on:
July 31, 2013 - 10:32:22 PM »
Thanks Neil and Dave. It isn't a bad leak but throws a little oil on my right brake.
Still working on the 5700 rpm miss. Can avoid it in first two gears by shifting at 5400 but around 95 mph it keeps me from finishing the quarter mile in power. 13.05 et should be at least a 12.5 . Especially with the MT streets I put on.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Front Crank Seal
