Author Topic: Early 90's Dodge Dakota auto trans... does it fit in an Ebody?  (Read 810 times)
Offline Cuda Cody
  • Vancouver, WA
A friend has a 90's Dodge Dakota 360 rebuilt Auto trans with over drive that he'll give to me at a super price.  Will these fit and work in a stock ebody small block 340 without any mods or wiring issues?  I'm guess the hump would have to modified, right?  Then the console?
Re: Early 90's Dodge Dakota auto trans... does it fit in an Ebody?
« Reply #1 on: July 24, 2013 - 01:37:10 PM »
Probably a 500 or 518 , I would take a tape measure to check mount location , some dakota engine block have unique block mount points , theoretically the 518 will bolt in with minor clearancing of the case
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: July 24, 2013 - 03:52:34 PM »
Thanks!
« Reply #3 on: July 24, 2013 - 10:14:48 PM »
I believe all the linkage [shift & kickdown] works with the 500/518 too
« Reply #4 on: July 25, 2013 - 12:18:00 AM »
 From the tail shaft forward should be the same as a 904/727. The tail shafts on the 500/518 are very wide. I thought modifying the x-member was mandatory. It would be nice if all it took was some tail shaft trimming. I've got a 500 out of a 92 Dakota sitting in the garage. It would be good for a future project if the car didn't have to be hacked.
Offline Cuda Cody
  • Vancouver, WA
« Reply #5 on: July 25, 2013 - 01:07:06 AM »
Thanks man!
Offline Jesus H Chrysler
« Reply #6 on: July 25, 2013 - 10:41:56 AM »
Wiring issues is a simple switch to engage/disengage the overdrive.  Power AND gas mileage!
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
