Author Topic: 1971 Barracuda filler tube mounting screws  (Read 689 times)
Offline John A
« on: July 24, 2013 - 07:25:48 PM »
Helping a friend with a 71 Barracuda and have a question. Is there a particular screw size for the filler tube for the gas tank ?. He found 4 but not sure if they are the correct ones. Thanks john.
Re: 1971 Barracuda filler tube mounting screws
« Reply #1 on: July 26, 2013 - 11:49:50 PM »
Phillips screw captive washer #8 about 3/4 inch long if I am not mistaken .
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: July 27, 2013 - 12:52:47 PM »
Exactly what I used.
Offline John A
« Reply #3 on: July 27, 2013 - 03:31:51 PM »
That helps out a bunch, thanks guys. John.
Offline anlauto
« Reply #4 on: July 27, 2013 - 03:45:04 PM »
No captive washer on the filler neck to tail panel as far as I know. There are captive washers on the rubber floor seal.
Does anybody have pictures of an original car using captive washers on the tail panel ?
