Author Topic: Driveshaft Shortening Question  (Read 817 times)
Offline cwestra
« on: July 25, 2013 - 08:16:28 PM »
Can a B-body driveshaft be shortened by removing material from the front or does it need to be removed from the rear only?
Corey - in Northern Indiana
Re: Driveshaft Shortening Question
« Reply #1 on: July 25, 2013 - 08:39:44 PM »
either end can be shortened but you can not go very far on the smaller tapered end obviously
Offline cwestra
« Reply #2 on: July 26, 2013 - 08:19:03 AM »
I was told that only the rear can be shortened because of the unique construction of the shaft (second tube inside or something like that).  Apparently it doesn't affect the rear somehow (maybe because of the tapered down diameter there).  I'm hoping you're right since there seem to be more B-body shafts available, but I want to be sure I can actually shorten it from the front.  Have you actually done one, or know someone who has?
« Reply #3 on: July 26, 2013 - 11:37:43 PM »
I have heard of the double tube issue , I have also shortened many driveshafts , I do not recall getting into an issue but sure as anyhing you will if I tell you it can be done !!
« Reply #4 on: July 26, 2013 - 11:52:55 PM »
Are the diameters of the small block driveshafts the same as the big block driveshafts?
The yokes on either end are different size.  Yet I've never compared the differences before of the two.
My thinking is: Take my small block driveshaft and convert to a big block driveshaft.
(If that's even possible)
Offline GranCuda1970
« Reply #5 on: July 27, 2013 - 02:09:11 AM »
Anything is possible if you have a donor driveshaft. I just got a big c-body driveshaft that had the 7290 ends and had it shortened for the 4-speed. There are alot of driveshafts that will work from other Mopars just need to take to a pro-shop and let them shorten  / balance and even put a new yoke on itf you want.
I must say if you need a DRIVELINE CHECK OUT  Driveline Services of Portland you will not be disappointed. Excellent service and quality of work.
 They can help and they ship!
Offline Cuda54
« Reply #6 on: July 27, 2013 - 10:30:30 AM »
I had Drive Line in Dubuque IOWA do my DS for my 72 Cuda it was a from full size car with the big u joints.
Offline cwestra
« Reply #7 on: July 27, 2013 - 11:54:55 AM »
I assume they cut from the front on that one, then?
