Does Anyone Have Any "How To" Articles on Gen III Engine/Trans To E-Body Swap???
Author Topic: Does Anyone Have Any "How To" Articles on Gen III Engine/Trans To E-Body Swap???  (Read 8038 times)
Offline 1970GranCoupeConvert
I'm just toying with the idea of swapping out my 340 and LA-727 with Gear Drive to a Gen III Hemi and transmission.
Ive done three transplants of modern engines and transmissions (Tahoe engine/trans into a 1961 Cadillac, Corvette LT-1 engine and trans into a 55 Chevy and a Camero LS-1 engine/trans into a 55 Chevy) but I am really unfamiliar with the modern Mopar equipment.
I talked to Randy Bouchillon of Bouchillon Performance Engineering and he said that the ONLY automatic transmission that would work is the 545 transmission from a 3/4 ton truck.
Many of the articles on the web seem to be outdated (2009).
So the questions are:
Can you shoot me (and everyone else) some articles on this kind of swap?
What engine and automatic transmission do you recommend?
From what donor car should these components come from?
Does the computer need to be purchased with the engine?
Who are the good companies to buy the wire harness and ECU reprogram from?
Will the OEM speedometer from the 1970 Barracuda still work with the new transmission?
Anyhoo...I know these questions are often asked however it would be great to get some feedback from guys who have done this very recently and who can give some real world experience and suggestions.
THANKS!!!
1970 Plymouth Barracuda Gran Coupe Convertible
First Car (purchased in October 1985)
Drove it throughout high school and early college (still do)
Full Frame off (K frame off) Rotisserie Restoration completed in 1991
Originally (and still is) a Rally Red, Black top with Charcoal/Silver Interior
340 CID with Holley Pro-Jection 4Di
LA 727 GearVendor  Overdrive
390:1 8 3/4 Rear end
Rally Rims (color matched)
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
http://www.carcraft.com/techarticles/ccrp_0905_hemi_engine_swap_guide/viewall.html        http://board.moparts.org/ubbthreads/showflat.php?Number=3930520
« Last Edit: July 26, 2013 - 04:36:25 PM by johns cuda shop »
Thanks...That article is good but it is from 2009...and it is kinda vague on details and there are some new engine designs that have come out since then.
 :horse: :horse:
 :horse: :horse:
Well it kinda gets you in the ball park. I was not sure what you had in mind for a budget, Its not for the faint of heart thats for sure Several members on the forum have either done the the swap or is in the process of.My gen 3 hemi build thread http://www.cuda-challenger.com/cc/index.php?topic=75207.0 I bought most of my drivetrain from Randy , he knows his stuff . Dont short change yourself of the swap because it will come back to bite you. If you have any questions, I would be happy to give you my personal experience.I wouldnt hesitate to contact Randy Bouchillon or Dave over at Modern Muscle.  :bigsmile:
« Last Edit: July 26, 2013 - 05:48:07 PM by johns cuda shop »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Ive done three transplants of modern engines and transmissions double the price for a gen 3 build
I talked to Randy Bouchillon of Bouchillon Performance Engineering and he said that the ONLY automatic transmission that would work is the 545 transmission from a 3/4 ton truck.any small block chrysler trans will work also
Many of the articles on the web seem to be outdated (2009). not much has changed
What engine and automatic transmission do you recommend? how much do you want to spend 5.7 are the cheapest  727 is or any standard shift other autos will require tunnel mods and a controller
From what donor car should these components come from? any gen 3 package will work
Does the computer need to be purchased with the engine? no but it could be used for a core charge
Who are the good companies to buy the wire harness and ECU reprogram from? IMHO hot wire auto makes the best one for a factory ecu and is carried by most of the vendors you mentioned  http://www.hotwireauto.com/?page=sales-dcx  holley is working on a nice standalone ecu and harness for about 3k
Will the OEM speedometer from the 1970 Barracuda still work with the new transmission? yes you may need an adapter if you use a modern auto
my car
http://www.moparmusclemagazine.com/featuredvehicles/e_body/mopp_1108_1970_dodge_challenger_lucky_dog/
a buddy's car I helped with
http://www.moparmusclemagazine.com/featuredvehicles/e_body/mopp_1302_1974_plymouth_barracuda/
my build thread
http://www.cuda-challenger.com/cc/index.php?topic=41617.0
there are several others on her like johns and Travis's that are really cool...
THANKS!!!
Go Fast & Have Fun...
Thanks Scott.
I went to your thread and could read the text however on the first couple of pages when I click on the pictures I get a message that says "404 - Attachment Not Found"
Is anyone else getting that message.
Regarding the "tunneling" work required with a new automatic, what work is required?  I have read threads about the 518A and it appears that the trans mount needs to be lowered and a "dimple" pounded into the floor board at one place but there does not appear to be major sugary required?  I will go with an automatic.
What are the differences in the modern automatics?
    • THE DODGE BOYS
Thanks Scott.
when I started the C-C server would clear the picture folder when it got full and we would lose all the pictures so I switched to photobuck but I never went back and reloaded them.
that's why the pictures are missing
shelbydog did a nice write up on the 518 install do a search or pm him for the necessary info
overdrive  :bigsmile: mostly, the modern trans are larger and need a controller to shift them and some use a bolt on drive shaft instead of a slip yoke.
The new 8 speeds that Chrysler is starting to use is something that would be fun to play with.  :burnout: until then if I were building an auto car I would look at the GM 4L80E 6 speed IMHO
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
6L80E with tap shift :)
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
One of the best threads I've seen on the install, and I referred to it alot is this one on Moparts,  How-To install a 5.7/6.1 HEMI into your 'ole Mopar! by 808Cuda
Its for a 6.1, but nearly all of it applies to the 5.7.
Here's the thread.
« Last Edit: July 31, 2013 - 06:54:46 PM by PlumCrazyChris »
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline Travis72
 :iagree: with PlumCrazyChris, I used that thread continually as a reference for my Gen 3 swap.
I think Bob with the Twisted Fish Cuda got the NAG1 working.  He used a FAST XFI system for the engine and a stand alone controller for the transmission if I remember right.  Check out his build thread for one of the nicest Cuda's you'll see.
http://www.cuda-challenger.com/cc/index.php?topic=28388.735
Travis
72 Cuda
Thanks...the Hawaii car thread is real good...my thanks to rain that allowed that gave that guy the time to write it up...and thanks to that guy for helping us all out.
He answered many of my questions regarding the engine install.
He used a LA-727 and that makes the hard swap much easier however I really want to go with the computer controlled transmission.
So it is confirmed that the 545 installation needs some tunnel mods to make the install...now the nagging question for me (and I'm sure other guys) is will the NAG1 swap require surgery to get it to be installed.
Oh, I,ll bet that there will be some major surgery to the crossmember .A lot of guys stick them under the tunnel without thought to the driveline angle.
« Last Edit: August 04, 2013 - 11:16:32 AM by johns cuda shop »
Wow that will be a super nice ride when he is done!!!
It looks by the picture he is going to install the 545 transmission and it is indeed a more thicker trans than the 727/904.
Regarding the NAG1...it is much shorter and more narrow than the 545...
Anybody with NAG1 experience...anybody...tap tap tap squeal...is this thing turned on...I'm here all week and remember to tip the waitresses?!?!?!?
(Looking around for more dead horses to beat emoticon)
 I am not sure what type of plans you have for the suspension ,. Your driveline angle will have everything to do with the tunnel surgery with any trans swap. Regardless of a Nag3 ,545RFE ,727 Unless you are happy with the factory setting ??  But why ? your already modifying the car for the modern drivetrain .Mopar set it a 3 deg down as standard in the 60s and 70s . If you set it at the factory driveline angle then you are limiting how far you can lower the car ,hence headers pointing downward, A unfinished look,exhaust head pipes hanging under the car ect ect. , A 1 deg down driveline angle gives you more options  . Just food for thought before you get started. I wish you luck on your project  :bigsmile:
Thanks John for the suggestions...very good thought process (on your end)!!!
Yeah...I admit I march to a different guitar.
My Barracuda sits at stock heigth.  Currently other than modern low profile and very wide tires and the fact tht I color coded my Rally Wheels the car looks exactly stock.
I had it slammed back in my high school years (like 28 years ago) but I got tired of the rough ride and scraping my assets on every speed bump so I raised it back up to stock heigth and have been very happy ever since.
Exhaust wise I am currently running stock high performance exhaust manifolds and and complete dual exhaust system with resonators.  It has a deep tone but not too loud.
If I go the Gen III HEMI route, I will try to see if the Jeep exhaust manifolds will work (like MP suggests) or I will try to go with shorty headers. I most likely will go with a new exhaust system of undetermined design and components (Ill beat that dead horse on this forum if/when the time comes.
 :clapping: :clapping:
